Results 1 to 2 of 2
Thread: irrigation loops
    Default irrigation loops
    What sort of flow control is required and sensible to place on a line between exterior spigot and an irrigation loop?
    I want to create a loop between two outdoor spigots. From the loop, I plan to add vacuum breaker for each branch that draws from the loop. The loop would be underground. I know that one spigot in theory could push water from the exterior main loop into the house without flow control - which I want to prevent.
    You have a bad "theory" and you CAN'T safely connect two hose valves to the same loop. Where, and what type, backflow preventers needed depends on the way you install the system so we would need a drawing of what you want to do, at least to the area control valves.
  1. When are pressure balancing loops necessary?
    By MKeel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-28-2011, 03:47 PM
  2. Gravity vs Pump recirculating loops - which is more energy efficient?
    By benze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-25-2010, 09:16 AM
  3. Heat Pumps MORE Efficient to run that hot water loops ?
    By chefwong in forum HVAC Heating & Cooling
    Last Post: 04-21-2010, 06:22 PM
  4. PEX slack & loops
    By miamicanes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2009, 05:12 AM
  5. PEX expansion loops & droops vs need to drain the line?
    By AcidWater in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-19-2008, 07:47 AM
