Results 1 to 5 of 5
Thread: Combination Wye On Its Back/Side
    DIY Junior Member philwgreen's Avatar
    Apr 2013
    Dallas, TX
    Default Combination Wye On Its Back/Side
    I was underneath the house the other day and noticed a couple of combination wyes in the plumbing on their backs/sides.
    I know there are differences on which fittings can be on their sides/back and I was curious if these were done correctly. We moved into the house about a year and a half ago and my best guess is that these pipes were redone about 5 years ago - but based on the previous owner's other handiwork I wouldn't be surprised if the entire DWV system is wacky.
    First one is the drain from a bathroom sink. The vertical continues as a vent through the roof.
    On the second, if you can look past the mess of romex (another project for another day) two toilets connect into the main stack with a combination wye on its side.
    Aug 2009
    South*East
    A combo is the same as a Y and 45. Perfectly fine.
    John
    Jan 2008
    The combos are fine. A sanitary tee would be improper.
    The strapping used is a bit hokey, as is the NM wire that could use some cable staples.
    Nov 2009
    Victor, MT
    The fittings are installed correctly.
    Apr 2013
    Dallas, TX
    Thanks for the replies!
    If you think the strapping and NM look hokey - you don't even want to see the rest of the basement! We gutted the upstairs and started over - it was bad.
  1. DWV Piping Dilemma from Adding wall-mounted toilet on one side of back to back setup
    By DIY_Steve in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2013, 09:19 PM
  2. Vespin II seat side to side play
    By magnumip in forum Toilet Forum discussions
    Last Post: 12-08-2011, 02:01 PM
  3. Help! Toto ultramx rocking side to side- does it need to be shimmed?
    By DIYjulie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-24-2011, 08:56 AM
  4. Electric Water Heater Side and Back Wall Clearances?
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-20-2011, 02:12 PM
  5. Tub drain and stack side by side... how to connect
    By louk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-12-2008, 08:55 AM
