Results 1 to 6 of 6
Thread: Water Softener Help
    DIY Junior Member yuxinhong's Avatar
    Apr 2013
    Los Angeles
    Default Water Softener Help
    I need an advise on which water softener to buy.
    4 bathroom, 3 shower, the master shower has 3 body spray and 2 shower head.
    family has 3 adults and 3 child.
    1 inch water main line.
    my city water report is at
    http://www.ci.glendora.ca.us/Modules...ocumentid=6587
    i think i have around 12-15 hardness.
    After done some research on the web and made few calls.
    my choices are
    Flex 5600 sxt, 64000 grain- but i am afraid the flow rate will be limited too much since internal is only 3/4
    flex 5000 sxt 64000 grain ( Fleck ProFloSXT) - one person told me this is better choice than flex 7000, but not sure why, and from the spect i think 7000 is better and not many are selling this model..
    flex 7000 sxt 64000 grain - this is the one i feel i should get, but someone said this unit has many problems before, and others said all been fixed already.
    can you help me to pick the right one, and can you also recommend which site has good after sale service and can always be reached at.
    thank you
    Nov 2010
    Maine
    If you have flow concerns, the fleck 7000sxt is the valve you want.
    Jan 2012
    California
    2 cu. ft. 7000SXT for your application will be fine.
    Apr 2013
    Los Angeles
    thank you , should i stick with 64k or should i get larger?
    can anyone recommend a internet store to purchase from?
    thank you
    DIY Junior Member Constru Expert's Avatar
    Jun 2013
    Florida
    Check out this article article about how to choose a water softener:
    Nov 2005
    Central Florida
    I mentioned several companies in ths thread: http://www.terrylove.com/forums/show...ener-companies. I've personally used qualitywaterforless and been generally pleased.
  1. How to empty water softener? (Kenmore deluxe demand water softener 625)
    By birkoff in forum Water Softener Forum, problems, installation and reviews
    Last Post: 01-22-2013, 08:56 PM
  2. Water softener WHES40 & Central Water Filtration System - Questions
    By reggiev6 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 12-16-2011, 10:57 AM
  3. Ancient Water Softener Guidance, Advice, and Spraying Water All Over the Garage
    By DavidK in forum Water Softener Forum, problems, installation and reviews
    Last Post: 06-03-2011, 12:41 PM
  4. Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order?
    By chuck b in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-09-2011, 05:21 PM
  5. Water softener, metal studs, water meter, copper pipes...
    By pghsebring in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-14-2010, 08:54 PM
