Results 1 to 10 of 10
Thread: packing for plastic faucet?
    DIY Junior Member cscjjd's Avatar
    Apr 2013
    Louisiana
    Default packing for plastic faucet?
    Hi,
    I am wondering if I can use graphite packing string on a plastic hot water cutoff valve
    (the original packing (seemingly a plastic washer) has disintegrated).
    If not, would you have other suggestions? (the valve will be a big job to replace and I don't have the time at the moment).
    Thank you!
    Yakima WA
    I'd suggest you pack that el cheapo cut off valve to the garbage and buy a real one.
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    Graphite packing would probably work if there is some sort of metal or plastic ring to keep it from getting into the threads on the stem.
    How about a picture of that "plastic valve" so we can see if there is even a place to put the string packing.
    Nov 2009
    Victor, MT
    I was thinking brass valve with a plastic stem. I have never seen an all plastic angle stop, but maybe I just haven't lived. A picture would help.
    The push on Accor valves are basically all plastic, but I visualize that this person is asking about a "T handle" PVC or CPVC ball valve, or a plastic gate valve.
    Apr 2013
    Louisiana
    Here are pictures of a similar valve as I had found some packing (also in the picture) and put the original valve back into service.
    The packing has stopped the water leak however a bit of clear, slightly viscous slime material has oozed past the packing nut. I can
    only imagine it came from the packing material (the plumbing supply store didn't have packing material and suggested I go to a local Rubber and Gasket Supply store where the clerk cut a piece off a roll for me-- I didn't see the roll where the piece was cut from -- the clerk said it was graphite or Teflon packing).
    I am curious if this ooze is normal -- it was only a few drops which I wiped off the packing nut. The valve is a cutoff for the bathtub hot water supply and had been in place about 20 years before it started leaking.
    Thanks!Name:  CIMG0985.jpg
Size:  35.0 KBName:  CIMG0984.jpg
    That valve does NOT use a "string packing", and it is NOT a "packing nut". It is a stem removal or assembly union. If you removed the stem you should find an "O" ring in a recess around the stem.
    Apr 2013
    Louisiana
    Hi HJ,
    yes you are right, the original "packing", seemingly a plastic washer or 'O" ring, had disintegrated after 20 years and I could not find an exact replacement -- that's why I wondered about using string packing. Though the string packing does seem to be working, except perhaps for the slightly viscous slime material that oozed past the stem removal nut (discussed in previous post with the pictures), I gather from your reply that this may not be a good long-term solution?
    Thanks for your replies and expertise HJ!
    In order for the string packing to work, it would need a washer between it and the valve body to compress the string. But there is no 'groove' in the valve body to recess that washer.
  1. Does shower faucet stem packing nut need to be removed before removing the stem ?
    By carlegeo in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-29-2012, 07:04 AM
  2. Prier Outdoor Faucet Plastic Cap
    By teqnic in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-26-2009, 04:47 AM
  3. plastic faucet tube
    By christoff in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2008, 08:16 PM
  4. White plastic debris plugging faucet. Bad dip tube
    By cbs1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-18-2006, 10:57 AM
  5. Extra plastic tubing out of a utility faucet
    By williamson_39 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-23-2005, 08:44 PM
