Results 1 to 5 of 5
Thread: No water out of the faucet?
    DIY Junior Member trawlerphil's Avatar
    Apr 2013
    North Carolina
    Default No water out of the faucet?
    The fact is Iím not too proud to show my ignorance. I must have changed out a whole bunch of these $20 Lowes faucets over the years in my rental units and boats, but this one has me stumped. It started when the hot water would come out for a microsecond and then stop, even with the faucet wide open. I shut off the water to the faucets under the sink and figured it was the faucet itself. I took the plunger apart, cleaned everything and put it back together, same result, no hot water.
    I disconnected the water lines to the faucets, removed the entire faucet assembly and replaced it with a brand new $20 unit, connected everything, turned on the water valves and voila-- same problem with the new faucet!
    Logically, this leaves two potential bad-boys, a bad on/off water valve, or a defective faucet unit. I did crack the water valve a bit while it was disconnected and water came out.
    Color me stumped! Any thoughts?
    Jan 2008
    Use a supply hose on the angle stop and flush the line into a bucket. This will prove water is available and flush any debris that might be in the line.
    Why didn't you check for water flow from the supply lines BEFORE you replaced the faucet? Or at least blow through the faucet with the valves open to see if it was plugged up? My customers would go ballistic if I started replacing things before I even knew what, or where, the problem REALLY was.
    Are you using the Watts Flood Safe connectors?
    They shut off the water if there is too much flow. If so, chuck them and put on standard supplies.
    If it's a multi-turn shutoff at the wall, it might be the washer.
  1. Moen kitchen faucet with spayer. Now water from faucet and pulsating from spayer
    By lmabadie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-11-2011, 02:20 PM
  2. Bathtub hot water faucet - no water comes out
    By LBrandt in forum Shower & bathtub Forum & Blog
    Last Post: 03-22-2011, 07:37 AM
  3. New Peerless faucet, water comes out shower head and faucet
    By pmgreen4117 in forum Shower & bathtub Forum & Blog
    Last Post: 11-19-2009, 06:01 PM
  4. cold water pressure in faucet slower than hot water!
    By m3gtr in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2009, 11:50 AM
  5. Broken O-ring?: Water leakage at the handle faucet, then suddenly no water at all!
    By decemberrr in forum Shower & bathtub Forum & Blog
    Last Post: 04-07-2008, 07:09 AM
