Results 1 to 12 of 12
Thread: New to well ownership - have a few questions.
    DIY Junior Member tjl5709's Avatar
    Apr 2013
    Michigan
    Default New to well ownership - have a few questions.
    Purchased a home with well. Home/well is about 12 years old. Well tested good during inspection. Treatment is setup as follows: 20" prefilter (20 micron) followed by Kinetco softener. Also have a reverse osmosis unit for drinking water at sink. Water is clear at all faucets. I get a little sulfur smell in shower once in awhile. I have no staining that I can see in any of the bathrooms. I had the reverse osmosis unit serviced about 6 months ago, and we tested the softener as well and everything was fine.
    My question is in regards to the prefilter. The water before treatment is kinda turbid, and pressure drops because the filter loads. I went 6 months before changing which was to long (lots of silt/rust on filter, big drop in pressure). Just changed it at 3 months (I started to notice the pressure drop, silt loading was obviously not as bad) , and I think I need to change out at 2 months. The sediment on the filter appears to be iron and silt.
    I am not sure what is considered normal in regards to changing out filters. Just looking to see how best to protect the softener bed.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    They make a pleated washable filter that will save in replacement costs. I would clean the filter monthly and replace every 6 months. Having a restriction on water flow can prevent the resin from being properly backwashed and possible cause problems down the road.
    Apr 2013
    Michigan
    Quote Originally Posted by mialynette2003 View Post
    Thanks for the reply. Searched it out and found them. The prefilter I have is only 20" x 2.5" and is a spun filter. I like the idea of going to a pleated 20" by 4.5". Looks like another project for the list...........
    Nov 2010
    Ocala, Florida
    Quote Originally Posted by tjl5709 View Post
    They make a 20" pleated or you can use a connector to join 2 10" filters. With a 4.5", it will allow longer spans between cleaning.
    Central Florida
    If you want a real project, consider a backwashed sediment filter. Pricier up front, but you don't have to fuss with the filter every 2 months, and you filter down to 5 micron. Here are a couple of vendors: http://www.cleanwaterstore.com/sedim...ckwashing.html, http://www.ohiopurewater.com/shop/cu...me.php?cat=484. Look around this forum for several interesting threads about backwashed sediment filters.
    In the shower, is your sulfur smell in the hot water only, or in both hot and cold?
    Jan 2012
    California
    I prefer automated backwashing filters using Nextsand, filterag +, turbidex, micro-Z, etc. All of these are nearly identical medias. All will filter down to 5 micron and require almost no maintenance.
    Otherwise, buy the sediment filters in bulk and replace as needed. My time is too valuable to clean a pleated filter. If you are retired and bored, then they are fine but...
    Another option might be to try a Lakos TwistII clean filter ahead of everything, These little filters do wonders! http://www.twistiiclean.com/installation-operation.html
    Central Florida
    Neat! If they came in 2", it might work on my irrigation line from my eutrophic lake...
    Jan 2012
    California
    Quote Originally Posted by Mikey View Post
    http://www.lakos.com/downloads/liter...h_TechInfo.pdf
    Central Florida
    That's a 2" Universal Flange filter -- how does "universal flange" connect to and compare with 2" PVC pipe?
    DIY Junior Member mtw's Avatar
    Sep 2013
    Florida
    You could always try a Rusco filter for 2" PVC http://rusco.com/index.php/product1/...rapper-filters
    Jan 2012
    California
    A simple flange adapter would be fine. See this link, McMaster is one of the best website a DIY'r will ever find!
    http://www.mcmaster.com/#plastic-pipe-flanges/=oe4lwo
    Nov 2010
    Maine
    most pool stores will have the flange.
  1. What a welcome into home ownership...
    By codeman1383 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-22-2012, 02:18 PM
  2. Pex questions
    By Lornescot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-11-2011, 08:30 PM
  3. A few pex questions and Sharkbite brand pex questions.
    By lee_leses in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-04-2011, 02:43 PM
  4. Okay Okay I am now trying it the right way but still have questions
    By Pdschu in forum Pumps and Tanks Well Forum & Blog
    Last Post: 09-22-2007, 04:44 PM
  5. Three Questions About 10-2
    By molo in forum Electrical Forum discussion & Blog
    Last Post: 08-20-2007, 02:36 PM
