Results 1 to 10 of 10
Thread: First time poster. Need help with tub fixtures!
    DIY Junior Member zsnyder's Avatar
    Apr 2013
    South bend, IN
    Default First time poster. Need help with tub fixtures!
    Hey guys, just bought my first house, i've been diy-ing as much stuff as i can. I was wondering if anyone can help me out with something that has me completely stumped.
    Just installed new tub fixtures (spout, shower head, handle) by delta. I got new cold/hot shut offs installed, connected flexible water lines, turned on the cold and it worked. Turned off cold and turned on the hot water, could hear it run to the line when i turned it on, but then when i went to the bathroom to turn on the hot in the tub, nothing happened.
    I'm not sure if I have something wrong with the tub, or what the deal is? Any ideas? I do have hot water in the sink in the bathroom, so it's not an issue with the water heater. Also, when i disconnected the water line, there was hot water at the rim of the connection point, but of course, nothing runs through.
    If you do not have BOTH hot and cold turned on it is not supposed to deliver ANY water, even cold. What kind of "flexible water lines" do you have, especially if you can "disconnect" them?
    Apr 2013
    South bend, IN
    hj, they are just simple flexible supply hoses, ones like you use to connect sink faucets.
    [img]http://www.*******************/images/mega-flow-super-water-flex-75fip-75fip.jpg[/img]
    One is an aluminum type one that is connected by nuts, and the other is a newer plastic type.
    I can try and take some pictures tomorrow if this would help. So you're saying it may be something as easy as turning both on and running them? Sorry if these aren't proper terms for these items. I'm not well versed (yet) in plumbing terminology.
    All modern tub/shower valves have antiscald technology in them, and require BOTH hot and cold water supplies to be on at the same time to work. If you only have one on, the safety valve MIGHT get lodged at one end, and need some help to return to its 'normal' position and let water through. This is more of an issue with an older valve. Just turn both the hot and cold on and see if it works. If not, a whack with a rubber mallet may dislodge the spool valve.
    Nov 2009
    Victor, MT
    Those flex are not approved inside a wall. You don't want to do it that way.
    They are also usually too small to give good volume to a shower valve. They are LABELED "not for use in concealed locations". If the cold worked with the hot turned off, it should not have, so the balancer might have gotten jammed to the hot side. if so, you won't get hot water even with both turned on.
    Apr 2013
    South bend, IN
    Quote Originally Posted by asktom View Post
    cool, thanks guys. Like i said, this is my first house and i don't have a lot of experience with this. Can you guys suggest a good place for me to read up on how or what I should connect the tub with? I always thought flexible lines were the way to go with this?
    Thanks again.
    Nov 2009
    Victor, MT
    Read up here. What kind of pipe do you have... threaded galvanized, soldered copper, PEX, CPVC or... ? A picture is worth a bunch of words.
    Apr 2013
    South bend, IN
    I'll take some pics tomorrow and post them up. Thank you again.
    Apr 2013
    South bend, IN
    ok guys... been busy sanding floors and doing lights. Thankfully i can do these things a little better than plumbing. Here are some pictures. Any help is awesome.
    this is a picture of the delta piece where the water/shower/tub connects:
    http://img.photobucket.com/albums/v4...4-26190330.jpg
    this is a pic of the 2 shutoff valves. One is pvc, the other appears to be galvanized.
    http://img.photobucket.com/albums/v4...4-26190321.jpg
    here's a pic of the whole thing.
    http://img.photobucket.com/albums/v4...4-26190308.jpg
    ideally, i'd like to do this myself if it's a fairly easy fix. I didn't put in any of this plumbing, except the delta piece, so if it's screwed up, let me know! Thanks
  1. Flex time or dead time ????
    By lextor in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-17-2013, 11:20 AM
  2. First Time poster Need help with water well installation
    By EdSmithx in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-18-2012, 07:23 PM
  3. funny toilet poster
    By kofola in forum Toilet Forum discussions
    Last Post: 09-30-2009, 02:34 PM
  4. *Well Pump keeps shutting off (Rapidaytor) from time to time*
    By h2osho in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-19-2009, 05:53 AM
  5. 1st time on and all zones running at the same time?
    By Spilly in forum Irrigation / Sprinkler Forum
    Last Post: 04-15-2008, 12:21 PM
