Results 1 to 8 of 8
Thread: Use a pressure balancing valve and ball valves for shower controls
    DIY Junior Member ceiiinosssttuu's Avatar
    Apr 2013
    Idaho
    Default Use a pressure balancing valve and ball valves for shower controls
    I am building my own house and finishing up my rough-in. For my stand-up shower (no tub), instead of buying a brand-name shower kit (Moen, American Standard, etc) I want to install a pressure balancing valve, stub out with ball valves that turn hot and cold on/off, and use a T to go up to the shower head. The finish look will be very simple and industrial-looking. Can someone describe how to plumb this? Or is there a schematic/diagram somewhere that would explain it?
    The pressure balancing valve has to "sense" the incoming pressure so it goes first. Ball, or gate, valves would be very "imprescise" for a volume control, "globe" valves would be better. I am not sure how "simple" it would look, but it would definitely be "industrial", or rather "factory rest room".
    Apr 2013
    Idaho
    Yes, a globe valve is what I was thinking - not a ball valve. So I would run the hot and cold supply through the pressure balancer, then a globe valve on each, then a tee connecting them and up to the shower-head?
    That's about it. I can't say it would be the most attractive shower I had ever seen, however.
    Apr 2013
    Idaho
    Thank you, hj! Now here's another question: I have another shower I want to do dual shower heads on - I roughed in 2 1/2" pex for hot and 2 1/2" pex for cold to the general area. I would like 1 set of globe valve controls for hot/cold and a ball valve to turn the second shower head on/off. How would I plumb this using the same pressure balancing valve scenario above?
    I assume you mean two 1/2" hot and cold lines, rather than a 2 1/2" hot and cold line, but why I cannot fathom why you would need two. A "three way ball valve" would keep your industrial look and change from one head to the other, (half way would operate both of them).
    Apr 2013
    Idaho
    The 3-way ball valve makes sense. I ran two of each because I thought one each of 1/2" would not be enough flow for a dual-head shower. Is there a pressure balancing valve that would take four 1/2" pex lines (2 hot, 2 cold), or do I need to tee them together and make two 3/4 lines first? Or use 2 pressure balancing valves and then join the hots/colds after they leave the valve? Thank you for your help!
    If you stay with Federally approved showerheads, they can't provide more than 2.5gpm each. So, it then comes down to the valves ahead of it. 1/2" pex likely wouldn't provide full flow for two, but certainly would for one. I doubt you'd find a PB valve that had multiple outputs...but, adding a T should work if the supply is big enough. As to the valves, you'd have to read their specifications carefully to determine their maximum flow rates. 1/2" pex should be able to provide 4-5gpm, copper about 20% more. 1/2" pex has the approximate ID of 3/8" copper.
  1. Replies: 4
    Last Post: 10-04-2010, 11:17 PM
  2. Pressure Balancing Valve Output
    By bbradski in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-15-2009, 07:53 PM
  3. Pressure balancing valve stuck
    By zone29 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-19-2008, 06:34 AM
  4. Trouble with pressure balancing valve
    By jasdyer in forum Shower & bathtub Forum & Blog
    Last Post: 05-04-2008, 08:14 PM
  5. Pressure balancing valve problem
    By Bill_R in forum Shower & bathtub Forum & Blog
    Last Post: 02-25-2006, 01:41 PM
