Page 8 of 8 FirstFirst 12345678
Results 106 to 116 of 116
Thread: Toto Soiree or Guinevere review, installing, comments and pictures
  1. #106
    DIY Junior Member dinkledoodle's Avatar
    Jun 2009
    Clearwater, Florida
    Oops! Not a pleasant experience yesterday. First, the plumber sent out by my "Silver rated" Toto dealer couldn't figure out how to install the toilet. He got all the way to dropping the cone into the adapter and couldn't make it fit in. He said it wouldn't fit because there wasn't enough space to the wall and I needed to strip the tile off the wall. After he left (with a $155 check), and I got over my shock and removed the bottom 6 tiles, I tried to seat the toilet and found I was having the same problem. Then the answer came to me.... Press down. With a little pressure the cone slipped into the adapter as smooth as silk. The 2 hours I'd spent stripping tiles off a 40 year mortar bed was totally unnecessary. So, why am I still unhappy. Check out the video. I know these toilets are super flushers. What's wrong with mine? And what's with that pathetic gargling at the end of the flush. I know I'm missing something pretty obvious but, frankly, I'm exhausted and my brain just ain't functioning. Thanks in advance, guys...
  2. #107
    Pull the tank lid cover off and make sure that the refill tube from the fill valve is pointed down the overflow tube.
    This is what refills the bowl.
    If the bowl is not full at the beginning, then the flush from the tank only fills the bowl, it doesn't flush the bowl.
    I'm sorry that you installer was clueless.
    Yes, you install the adapter with wax, bolts and screws to the floor.
    And then you drop the bowl onto that. Most homeowners figure that out pretty easily.
    It's too bad that many plumbers don't read the instructions. The paperwork that comes with the toilet shows how much room is behind the tank with a standard 12" rough. You don't have to guess at this.
    At 12", you should have 3/4" behind the tank.
    The next step after "reading" that, is to use a "tape measure"
    The two tools your plumber should have used were
    "reading glasses"
    "tape measure"
    The rest is common sense.
    An adapter installed on tile using the green inserts and the screws that come in the Unifit Box.
  3. #108
    Jun 2009
    Clearwater, Florida
    Thank you Terry. Sorry for the vent, but as I said I was just tired. This is how he attached the refill tube. It isn't the overflow, but it does point down it. And as you see there is still no flush. Oh well... (p.s. It was the 10" adapter.)
  4. #109
    Owning a couple of similar Totos, what you are seeing is not normal. It looks like you probably have a drain line obstruction or, when they installed the adapter, they blocked part of the drain with the wax.
  5. #110
    Jun 2009
    Clearwater, Florida
    I'm thinking so too Jim. There was wax oozing out all around the adapter. I never see that in Terry's pictures. We plan to call the company Monday.
  6. #111
    Jun 2009
    Clearwater, Florida
    Arrrrrrgh! You're not going to believe this. I walked in this morning, gave it a pity flush and voila! Flushed perfectly. What did I do? Absolutely nothing! I have no idea what happened. It was a miracle... I have a self-healing toilet...
  7. #112
    It's possible that you have a partial drain line blockage, and that overnight, it drained down so there was plenty of room for the waste water to go. It sounds like it's not the toilet at all, and a drain line problem.
  8. #113
    The Soiree and the Guinevere need the water supply 6" to the left of center.
    Most toilets can get by with 3" to the left of center.
    I used to plumb the water at six inches anyway, so it's not normally an issue.
  9. #114
    DIY Member glnow's Avatar
    Mar 2007
    CA
    Random question.
    Are current Guineveres, or other Totos that make use of the uni-fit, still prone to a dripping sound
    as soon as waste enters the bowl?
    All of the threads that talk about this are a few years old, and there was some speculation back then that Toto was going to change the plastic, or add a coating, or something to address the dripping sound. Just curious if that ever ended up happening?
  10. #115
    Mine are the older ones (no idea if they really changed them), and the sound is so subtle, once you understand what it is, it goes into the background noise like the furnace blower, ticking clocks, wind, etc. It really isn't a big deal. All toilets do this, but not many have some plastic in the drain line. The addition of those liquids or solids make more noise than the overflow going down the drain, and it equilizes shortly after those stop.
  11. #116
    Mar 2007
    CA
    Yeah I got used to it a long time ago, though it still gets annoying explaining exactly what you said above to visitors when they tell me I have a leak (can u believe, not everyone in the world reads toilet forums! I mean come on, what's wrong with these people ). I just got to wondering if Toto ever did anything about it, maybe with the 1.2 flush versions, for example.
  1. Toto Soiree and Guinevere toilet review and comments
    By JH in forum Toilet Forum discussions
    Last Post: 04-15-2013, 09:05 AM
  2. Toto Ultramax product review, comments & pictures
    By Reader Review in forum Toilet Forum discussions
    Last Post: 04-06-2013, 02:15 PM
  3. Replies: 54
    Last Post: 02-19-2013, 09:51 PM
  4. Toto Carlyle toilet Review, comments and pictures
    Last Post: 06-22-2012, 04:07 AM
  5. Toto Dalton toilet review, owner comments and pictures
    By Perfectionist in forum Toilet Forum discussions
    Last Post: 03-30-2010, 11:34 AM
