Results 1 to 5 of 5
Thread: Trying to Avoid A Major Disaster..Advice Needed
    DIY Junior Member cemian's Avatar
    Apr 2013
    Florida
    Default Trying to Avoid A Major Disaster..Advice Needed
    Hi everyone
    I was wondering if this could be a DIY job or does this need the services of a licensed plumber to solve? The inlet pipe going into the water heater has rust on it as you can see in the picture...can this be cleaned off and fixed or does the this pipe need to be replaced? Doing so will need the entire water supply of the condo building to be shut off affecting everybody in this building..so if I could find a solution to avoid this would be all the better...looking forward to your comments..thank you
    DIY Senior Member asktom's Avatar
    Nov 2009
    Victor, MT
    It needs to be replaced. You should get a plumber to do it.
    Yakima WA
    Most condo associations require that plumbing, electrical, and other building repairs be done by licensed professionals and condo owner are not to mess with these things. You should not DIY even if the condo association permits it because of potential liability issues should there be a mishap during or after the repairs. My advise is don't touch it. Check with the association on what their rules are and follow them. It does look like the valve should be replaced, but there may be more problems that you can't see. It doesn't appear that there is an immediate danger, so you have some time to work with.
    It should be replaced, but there is not enough room to "just" replace it. Some of the other piping will have to be revised to make room for the replacement. Probably NOT a DIY job.
    Apr 2013
    Florida
    Thank you for your responses...will have a licensed plumber take care of it then
  1. Advice Needed
    By arnowell in forum Pumps and Tanks Well Forum & Blog
    Last Post: 06-12-2011, 01:43 PM
  2. Replies: 3
    Last Post: 06-21-2008, 06:44 PM
  3. Plumbing Disaster at The Worst Possible Time - Advice Please!!
    By durstaj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
  4. Sump Pump disaster/failsafe solutions needed
    By GregN31 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-03-2007, 05:26 PM
  5. Advice Needed - What could be causing this?
    By mark1210 in forum Shower & bathtub Forum & Blog
    Last Post: 09-06-2005, 12:01 PM
