Results 1 to 3 of 3
Thread: expansion tank and back flow
Hybrid View
    DIY Junior Member dpw-ct's Avatar
    Feb 2012
    New York
    Default expansion tank and back flow
    I have this set up in my basement in a NYC condo for 10 years, I am now being told that this is a problem any thoughts on why there would be two check valves in this set up. Is it a problem . Arrows who direction of flow through check valves/back flow preventers. Supply is Cold water supply
    fyi at bottom of photo is a weil mcclain indirect water heater
    Name:  boiler unit g - final.jpg
    Feb 2012
    New York
    Do you think the lower check valve should be removed?
    Assuming that expansion tank is for the potable hot water expansion...there's not supposed to be any valve of any sort between it and the cold inlet to the WH, so yes, if there's a check valve there, assuming it's working, the expansion tank is isolated, and not doing its job. An expansion tank absorbs the increased water volume when you heat water in the tank...there has to be an unobstructed path to the tank.
  1. Questions about over flow value and adding a expansion tank
    By Sammy222 in forum Water Heater Forum, Tanks
    Last Post: 02-03-2013, 01:53 PM
  2. 2 Gallon Expansion Tanks...Hot water VS Well expansion tank
    By Its.me.again in forum Water Heater Forum, Tanks
    Last Post: 10-14-2012, 01:42 PM
  3. Replies: 15
    Last Post: 06-06-2011, 04:55 AM
  4. Expansion tank and regulator back flow pressure issue
    By IAMIR in forum Water Heater Forum, Tanks
    Last Post: 07-04-2010, 01:42 PM
  5. Clog at back flow device
    By JeffH in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-12-2007, 05:12 PM
