Results 16 to 30 of 32
Thread: Vanity Plumbing Options
  1. #16
    DIY Junior Member JD3263's Avatar
    Apr 2013
    FL
    What if I used a 2" double fixture tee and used 2" pipe instead, or reduce down to 1.5" when necessary.
    How would I go about framing a wall? Would i be building a new wall in front of the block wall? Is that only done to hide the pipes in the wall?
  2. #17
    Jan 2008
    There can be no decrease in the size as it goes downstream.
    It is common to install a regular wood frame wall and wallboard on the inside of a block wall. This is how many basements are finished. It also provides a place to run electric and plumbing in the wall.
  3. #18
    Apr 2013
    FL
    I was at Home Depot today looking at the air admittance vents and saw these two:
    Vent 1
    Does not meet ASSE 1051 which is required to meet the Interior Plumbing code.
    or Vent 2
    Which does meet plumbing code.
    There is a pretty significant difference in price if they both accomplish the same thing; however, I don't mind paying a little extra if it's worth it. Is Vent 1 really what I'm looking for?
    Thanks again for all the help!
  4. #19
    Jan 2008
    All I can say is when I held #1 in my hand it felt like a piece of crap, so I would buy the other one.
  5. #20
    Oatey makes an AAV that is legal.
    http://www.oatey.com/products/air-admittance-valves
    Legal Oatey AAV
    Not legal Cheater Vent
    The cheater doesn't list any code approvals.
    I would use a legit AAV, not a cheater.
    This one does list code approvals
    http://www.oatey.com/doc/6%20DFU%20Tubular.pdf
  6. #21
    Apr 2013
    FL
    So, I have all my parts and I began putting everything together. I needed to replace the existing hot water shut off valve, so I picked up one of those quarter-turn valves. After I tightened it, the valve had a very very slight leak out of the back of the nut...it was just enough that you could see a tiny bit of water on your finger if you ran it across the back of the nut, underneath the pipe.
    I continued to tighten it more, but it still seemed to have that slight leak. I let it go over night and checked it again when I got home today. There doesn't appear to be a leak now; it's completely dry if I run my finger over it. Should I be worried? Or could it have just been the water escaping that was stuck behind the ferule when I installed it?
  7. #22
    Apr 2013
    FL
    Well, here's the final result...
    Also, I took off the compression shutoff valve and put on a shark bite valve. It took 10 seconds to put on and it doesn't leak.
    Thanks for all the help!
  8. #23
    Jan 2008
    Ahhhh... forget it.
  9. #24
    Apr 2013
    FL
    Ahhhh... forget it.
    Now I'm curious...what is it?
  10. #25
    Apr 2013
    FL
    Well, I'm finished with the vanity; everything seems to be working properly with no leaks. Time will tell...
    Thanks for all your help!
Size:  23.0 KB Name:  Vanity 1.jpg
Size:  50.6 KB Name:  Vanity 3.jpg
  11. #26
    You used all the wrong fittings.
    You used water supply fittings, not waste fittings. You now have an impossible setup to snake when it's needed.
    The fitting below the ilegal cross fitting is a water pressure 90, not a long turn 90 bend.
    The 90's that turn out are the same, those should have been medium 90 bends.
    The cross should have been a double fixture fitting.
    The pipe below the double fixture fitting should have been 2"
  12. #27
    Apr 2013
    FL
    Well, I can't change it now...or at least I won't be changing it unless I run into a problem later. I designed it so I can slide the vanity boxes out if I need to.
    Those are the 90's the guy gave me at Home Depot. I showed him the exact same image I posted here and he helped me pick out the pieces. He said he is a plumber outside of HD and has been doing it for the past 30 years...I guess I got suckered.
    HD and Lowes didn't have any double fixture fittings, just those...
    Thank you for the information. I'll be sure to research the different types of fittings/90's you mentioned so that my next plumbing project will be correct.
  13. #28
    Nov 2008
    Chicago, IL
    Should of hired a plumber
  14. #29
    Apr 2013
    FL
    Quote Originally Posted by SewerRatz View Post
    I like to try and do things myself; it's more rewarding to see the final result. Albeit, it's usually better when it's done right.
    I've never done any plumbing before, or tile, or electrical, or anything to do with most of the other projects I'm working on, so it's all a big learning process.
    Thanks to you guys, I now know some more specific questions to ask if I do any more plumbing.
  15. #30
    Apr 2013
    FL
    I forgot to ask...
    Are you referring to the small section of pipe below and between the cross fitting and the 90? Or are you referring to the horizontal pipe that's running to the 90 before going into the wall?
    I thought it was illegal to reduce the size as it goes downstream? I'm pretty sure the pipe that comes out of the wall is 1.5", so in that case I would need to keep it 1.5", right? Otherwise I would be reducing from 2" to 1.5".
    Thanks.
  1. New Vanity and plumbing
    By whoosier daddy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2013, 02:48 PM
  2. Double vanity plumbing options
    By nawyner in forum Shower & bathtub Forum & Blog
    Last Post: 12-11-2012, 06:58 PM
  3. Need options for plumbing db vanity into 3" vert. drain/vent
    By sidac99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-28-2012, 03:00 PM
  4. plumbing for new vanity
    By RobertZ in forum Remodel Forum & Blog
    Last Post: 03-19-2012, 11:57 PM
  5. Plumbing a double vanity
    By moose186 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-13-2010, 07:15 AM
