Results 1 to 5 of 5
Thread: Walls not plumb...
    DIY Junior Member Msisell's Avatar
    Apr 2013
    Minnesota
    Default Walls not plumb...
    We have a concern, we just finished putting the backer board up in our shower and found where the wall meets it is not square. It looks good at bottom corner but as it goes up the back wall must be set back some. The gap in the corner starts from nothing to about an inch at ceiling. Should we take the cement board off and build it out somehow? I was told to just fill it in with the thinset but that won't square the tiles as i set them outwards from the corner. Maybe it will all work out just want to make sure before I move forward. Thanks for your time!
    Often the walls can be a little off.
    If you have put a level on it, and it's an inch off from bottom to top, that's a lot.
    When installing tile, you start from the middle and make your cuts in the corners. That way, most of what you see will be vertical, and the only tiles that are a bit off are in the corners. Your eye is less judgemental there.
    Apr 2013
    Minnesota
    Great thanks! Next question... Do I need to apply silicone or something where the cement board meets the homemade shower pan?
    Jan 2008
    An inch from top to bottom is a lot, and will make tiling a real pain. I would pull it down and work on straightening it out. Cutting some long tapered shims would be worth the effort you save in trying to make the tile look right later.
    Jul 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
  1. Did I plumb this right?
    By stockwatchn in forum Pumps and Tanks Well Forum & Blog
    Last Post: 07-21-2008, 11:20 AM
  2. Frameless Door and Walls out of Plumb
    By bluemax2 in forum Shower & bathtub Forum & Blog
    Last Post: 04-11-2008, 02:33 PM
  3. Is anyone familiar with Swanstone solid surface walls for bathtub/shower walls?
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-25-2007, 09:36 AM
  4. Plumb W/D
    By Eric2007 in forum Remodel Forum & Blog
    Last Post: 03-06-2007, 05:47 PM
  5. re Plumb
    By nypdlee in forum Remodel Forum & Blog
    Last Post: 11-29-2004, 11:22 AM
