Results 1 to 3 of 3
Thread: PEX for shower plumbing
    DIY Junior Member tlt3900's Avatar
    Apr 2012
    Cypress Texas
    Default PEX for shower plumbing
    Hi,
    I've read in a couple of places that PEX was not recommended for the drop from a shower valve to the tub spout and should not be used from the valve to the shower head. I'm not sure i understand why.
    I am hoping to use PEX in my shower from the pressure balance valve to the diverter and then from the diverter to each the rain shower head, hand wand, and the body spray pressure balancing loop.
    Are there any opinions one way or the other on this? Thanks for the advice and help
    Jan 2008
    The inside diameter of PEX is smaller than the equivalent copper pipe size. Running PEX to a tub spout can cause a restriction which forces water out of the shower head regardless of the position of the diverter.
    It is good practice in many situations to install PEX in the next larger pipe size than one would normally install when using copper.
    Apr 2012
    Cypress Texas
    Thank you cacher_chick, i understand now about the tub spout. I was planning on using 3/4 inch pex with a 3/4 inch pex to 1/2 inch NPT connection to the valve. Thanks again for the help. I see from your avatar that you are from Wisconsin. I live now in Houston but grew up in Rockford Illinois and lived in Menasha for awhile.
  1. Tub/Shower plumbing
    By REXAMUS in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-11-2012, 08:17 AM
  2. Rough Plumbing for Delta multiple shower heads in Tub/Shower?
    By jsarin1 in forum Shower & bathtub Forum & Blog
    Last Post: 10-15-2010, 08:22 AM
  3. Please Help Me With Shower Plumbing
    By seanmathes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-16-2008, 11:13 AM
  4. Shower/tub plumbing
    By bobv in forum Shower & bathtub Forum & Blog
    Last Post: 09-04-2007, 07:56 PM
  5. Replace shower Plumbing Valve assembly shower head 2 knobs
    By scri8e in forum Shower & bathtub Forum & Blog
    Last Post: 12-30-2006, 10:24 AM
