Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: Motor lockup due to shaft seal & impeller tightness ??
  1. #16
    Mar 2011
    Houston, TX
    Quote Originally Posted by AcidWater View Post
    no external cap.
    Did you get it apart ? If you are having a hard time separating the halves you can loosen the screws slightly and just lightly tap the head of the screws. You should not need a big hammer, just the handle of a screwdriver should work.
    Did you get your new one yet ?
    Good Luck
  2. #17
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    Tapping the loose screws is a good method. Have not messed with it yet. Have the replacement motor & very lazy in installing it. Not feeling like lying / kneeling right now. Wife hasn't yet complained about doing dishes by hand
  1. How to judge tightness of threaded connections
    By WendyH in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2010, 04:42 PM
  2. broken pump at bottom of well shaft
    By fleemanc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2010, 08:22 AM
  3. Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
    By on02151blueline in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 04:56 PM
  4. Wiring in air shaft
    By hans_idle in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2008, 07:49 AM
  5. Woodford Shaft Out But No Valve On End
    By kshomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 12:31 PM
