Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: Motor lockup due to shaft seal & impeller tightness ??
    DIY Senior Member AcidWater's Avatar
    Oct 2008
    Default Motor lockup due to shaft seal & impeller tightness ??
    Is it possible to wrongly install the shaft seal and drain impeller washer on a dishwasher so that they are too tight and thus cause the motor to strain or lockup ?
    I'm not talking about the necessary clearance so the impeller itself does not drag within its housing.
    How does the shaft seal work, mechanically? Does the shaft spin around the metal collar in the shaft seal, or does the face of the graphite ring on top spin against the bottom face of the impeller washer??
    I can see that the face of the graphite ring on top needs to press tightly against the corresponding face of the impeller washer to prevent a leak.
    The two faces spin against each other. You aren't going to give up on that dinosaur are you?
    Oct 2008
    Not until I know what's wrong with it. Learning stuff.
    The lower seal must not spin at all; otherwise the rubber on the outside diameter would abrade ??? So the washer on the bottom of the impeller spins against the stationary graphite ring on the seal?
    Even installing a new unit would involve changing or un-sticking the water inlet cutoff valve, so I'm going to shut off the house & see if I can make it work, it as my next step.
    Oct 2008
    The pump comes off of the motor...
    Only unique things about this motor are
    1) the pattern of the bolt holes for attaching the pump
    2) the pattern of the 3 studs which the retaining clips hook over
    But might this not be a standard sort of motor end plate?
    Oct 2008
    FOUND THE MOTOR
    factory Whirlpool/Kitchenaid parts center: 800-253-1301 and they still have the original parts numbers on their system.
    They said that the motor part number in my book is now 4711686. They don't have any more, but I snagged the one on ****.
    They also still have some rubber parts like the door seal !!!
    Mar 2011
    Houston, TX
    Maybe pictures would help.
    Call the Maytag Man, He has nothing to do and is waiting for your call.
    Oct 2008
    >Call the Maytag Man
    Gordon & Jesse have both passed on...
    http://www.imdb.com/name/nm0432410/
    http://www.imdb.com/name/nm0924964/bio
    But told the motor has replaceable bearings, so I need to learn how to do that. How do you get it apart after removing the 4 long bolts?
    Mar 2011
    Houston, TX
    Quote Originally Posted by AcidWater View Post
    If they are truly replaceable then,
    First thing that you need to do is mark the Motor Housing so that you can align it back up Exactly the way it is before you disassemble.
    The motor rotor shaft ends will need to be cleaned, so they can pass thru the bearings. Pull straight apart.
    You should use a Arbor Press to remove them from the housing. They are pressed into the ends of the motor housing.
    Next step, Buy a new Dishwasher and use that one to play with, then you can disassemble the Timer.
    Good Luck.
    Mar 2011
    Long Island, NY
    Good Luck.
    DON! you da man! I used to do that stuff when I was back in High School. Taking apart old washing machine motors, replacing bearings and those old cetrifugal start switches. Those were the days. Those old timers were fun too, especial those that you pulled the handle on and moved the slider to your "program" and pushed it back in, as opposed to the old rotary ones, that were also fun for me to fix if i could. I used to make some pocket money repairing appliances for neighbors, getting most of my parts from old machines other neighbors threw out. Its not that they did not know where those parts came from, as they benefited from the cost savings.
    Uh, yes they had appliances 55 years ago
    Oct 2008
    The top & bottom housing pieces are stuck nice & tight to the stator... should I spray WD40 to loosen them up? Am I going to need to tap them with a mallet or should they slide off easily?
    Mar 2011
    Long Island, NY
    Hmm, where is that crystal ball when I need it?
    I doubt if it will come apart too easily, but who knows? I'm looking for that ball now.
    Mar 2011
    Houston, TX
    They are fit tight together.
    WD40 won't hurt anything. You will not likely find new bearings. I would have used Turbine Oil and lubed the bearings without needing to disassemble.
    Can you take a picture of the Motor ?
    Oct 2008
    Photo here:
    http://www.automaticwasher.org/cgi-b...READ.cgi?22850
    I hesitate to whack on the ends unless that's the way its done. Do the pros put some sort of turnbuckles between the two ends and crank it open evenly?
    I'm told the bearings are a standard type of part.
    How can I get oil to the bearings without removing something?
    Also found this:
    http://www.fixya.com/support/t943723...ric_dishwasher
    >Flash is motor start switch it arcs while dis-engauging start windings is normal. just make sure winding do not appear to look blackish
    Mar 2011
    Houston, TX
    That motor may have a start cap, Is it good ?
    Oct 2008
    no external cap.
  1. How to judge tightness of threaded connections
    By WendyH in forum Shower & bathtub Forum & Blog
    Last Post: 05-17-2010, 04:42 PM
  2. broken pump at bottom of well shaft
    By fleemanc in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-08-2010, 08:22 AM
  3. Cast iron motor adpater cracked Goulds Motor Apapter Part#1K310
    By on02151blueline in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-18-2010, 04:56 PM
  4. Wiring in air shaft
    By hans_idle in forum Electrical Forum discussion & Blog
    Last Post: 01-05-2008, 07:49 AM
  5. Woodford Shaft Out But No Valve On End
    By kshomeowner in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-08-2007, 12:31 PM
