Results 1 to 12 of 12
Thread: Is this an S Trap - How to Fix?
    DIY Junior Member ParaDiddle's Avatar
    Apr 2013
    Buffalo, NY
    Question Is this an S Trap - How to Fix?
    So, I just installed a new floating vanity in our bathroom and it has limited space and pre-existing drain pipes. Would this be considered an S Trap and therefore illegal and not to code? We are listing out house for sale and I want to get it fixed before we sell it. This is a double vanity so I'll have to do this twice. This was the easiest way to hook into the existing drain because of the increased number of joints allows for many more axis of rotation and positioning.
    As you can see, there's already a 45 coming out of the wall and I would have to go into the wall to cut it out before the 45. There's maybe 5/8" pvc between the 45 and the threaded coupling for the trap to connect to. If I carefully cut off the threaded adapter is the 5/8" enough PVC to glue on new fittings to make a P Trap lineup? Also, I'd like to NOT cut out the bottom of the cabinet and have the p trap extend below it for asthetic reasons. Is it against code if I use some 90 degree elbows to raise the drain pipe a lot higher and keep my P trap as high as possible (meaning that the tail piece coming out of my sink would be very short). If I tried to connect my trap to the current height of the existing drain pipe, I would have to cut into the base of my cabinet for sure.
    Thanks for any expertise on this subject. The good thing is that I didn't glue my vanity top on yet or silicone the top edge, so worse comes to worse, I can take the vanity down and get into the wall.
    Nov 2009
    Victor, MT
    Yes, that is an "S" trap. If you put in a longer chrome tailpiece it looks like you could hook up to the line coming out of the wall as it is.
    Apr 2013
    Buffalo, NY
    Yeah, on 1 sink it "may" line up with the existing drain but I would have to cut the bottom of the cabinet out so the curved part of the p trap would fit (and hang below the vanity). The existing drain line is only about an inch off the bottom of the cabinet. You can see how I had to cut out the bottom brace of the cabinet just to hang it on the wall.
    Do you know if it's against code if I raise the drain using 90's to make it go up a bit and then towards the drain?
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    You have the wrong end of the p-trap attached to the tail piece. I think you have enough space to put it together correctly. The long side of the J should attach to the chrome tail piece. There is an extra J in there that you do not need. Then the long end of the L shaped pipe goes into the pipe at the wall. The short side of the L attaches to the short side of the J. The long side of the J is adjustable on the tail piece and the part that goes into the pipe at the wall is adjustable.
    http://www.youtube.com/watch?v=I1WcaS5n-ZU
    http://www.youtube.com/watch?v=wJa0_GqZGP8
    http://www.handymanhowto.com/2009/08...-drain-part-3/
    Aug 2009
    South*East
    I think it's still growing.
    John
    Apr 2013
    Buffalo, NY
    Quote Originally Posted by asktom View Post
    I would have to cut into the cabinet, which is probably what I'm planning to do now.
    The bathroom is only 8' deep with the toilet being the farthest and lowest point anyone would be able to get the proper angle to see below the cabinet and if someone see's a little pipe while they are popping a squat, then that's fine. I'm about 1.5 to 2" above the existing trap, so the pipe will only stick out about an inch after deducting for the thickness of the cabinet. I taped a pipe under there and I couldn't see it. I'm guessing children might see it, but that's no big deal.
    Apr 2013
    Buffalo, NY
    Quote Originally Posted by Smooky View Post
    Yeah, I know how a normal P trap goes, I just didn't have room in the cabinet without cutting a hole in the bottom. I think that's my best bet now because if I cut the drain pipe and can't get a new fitting on there without going into the wall, my wife will be very upset that she can't have her bathroom for another couple of days.
    Apr 2013
    Buffalo, NY
    Quote Originally Posted by johnjh2o1 View Post
    John
    I was thinking I might get a prize if I could use more pieces. I wouldn't have left it like that because I don't trust all those joints as my wife would undoubtedly knock them around. That's just how it is so she can use one of the sinks until I figure out my plan.
    Thanks to everyone who has left a comment so far too.
    Apr 2011
    NC
    I would cut a round hole where the p-trap will sit. I would cut it the size of a pie pan so the rim of the pan would set on the bottom of the cabinet. This would prevent things from falling into the hole you cut and give it a neater look.
    http://www.usfoodsculinaryequipmenta...FWcOOgodxHgAyg
    Apr 2013
    Buffalo, NY
    Thanks, that's actually a great idea, if it fits. It will be close. I can also spray paint it black to match the cabinet.
    Since it is a double sink installation, even if you opened the wall you would probably have a "lot" of plumbing to do in order to raise the drains, because you could not just use elbows to raise the openings inside the wall. Your drain connection is the typical, "Just put enough fittings together and it will work".
    You "fix" an S trap by venting it after the P trap and avoid making the S shape.
  1. Max vertical distance out of p-trap before going into trap arm
    By Hammerlane in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-31-2012, 02:18 PM
  2. P-Trap into floor drain? Or is that an S-Trap? (and not good)
    By bretm1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-22-2011, 07:19 AM
  3. Lav trap on larger trap arm: actual problem?
    By dave148 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2008, 07:34 AM
  4. Bathroom sink p trap or t trap
    By ksdad in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-19-2007, 06:36 AM
  5. Replace S-trap with P-trap or chicago loop?
    By staceyneil in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-05-2007, 08:06 AM
