Results 1 to 8 of 8
Thread: Can neutral and ground from 50A breaker be shared
    DIY Member rosem637's Avatar
    Jan 2013
    Michigan
    Default Can neutral and ground from 50A breaker be shared
    A run in 1" plastic conduit from the main panel to power a stove and a microwave. So individual conductors will be used.
    Stove is on 50A breaker with #8 wire, microwave on 20A breaker with #12 wire.
    The 1" plastic conduit will be run to a junction box and will contain four #8 conductors(red,black,white ,green) and one #12 conductor(blue).
    Question is....in the junction box can the #8 neutral and ground be connected to #12 neutral and groung conductors for the run to the microwave?
    Kind of like the diagram. Although I did not show the red and black for the stove continuing because it was getting crowded in the drawing.
    Jun 2007
    NY State, USA
    I guess the accurate replies here were not good enough: http://www.diychatroom.com/f18/share...-93896/index5/
    Mar 2011
    Houston, TX
    I guess this post was before a answer was given on the other forum.
    "No, you cannot do that."
    Be Careful playing with electricity.
    The logical answer would be that there is NOTHING on either appliance that "needs" a #8 neutral, and the ground in a JB is often a common for everything in it.
    Jun 2007
    NY State, USA
    Not quite.
    Jan 2013
    Michigan
    Quote Originally Posted by Speedy Petey View Post
    Not quite.
    Yes quite.
    Answer on other forum acknowledged at 0829. This post on this forum started at 0816.
    Do not know why the concern on how and when and where this question was posted. For info it was also posted on two other forums.
    Mar 2011
    Houston, TX
    Quote Originally Posted by rosem637 View Post
    Yes quite.
    I think that a GFCI will be required for your install.
    If you start sharing Neutrals strange things can happen.
    Good Luck.
    quote; If you start sharing Neutrals strange things can happen.
    Maybe if it is going through a GFCI or you overload it.
  1. Odd Hot-Neutral Reverse after Ground.
    By Dr.Guacamol in forum Electrical Forum discussion & Blog
    Last Post: 02-08-2013, 08:52 AM
  2. Subpanel neutral/ground isolation
    By Homeownerinburb in forum Electrical Forum discussion & Blog
    Last Post: 01-15-2012, 04:50 PM
  3. Subpanel Neutral & Ground On Same Bar?
    By slimjim43 in forum Electrical Forum discussion & Blog
    Last Post: 06-23-2009, 10:58 AM
  4. Shared neutral
    By beekerc in forum Electrical Forum discussion & Blog
    Last Post: 12-11-2008, 12:09 PM
  5. Neutral/ground at sub breaker panel
    By Cubey in forum Electrical Forum discussion & Blog
    Last Post: 08-18-2007, 03:17 PM
