Results 1 to 14 of 14
Thread: Ceramic Tile--What To Put Around Toilet Flange
    DIY Member rosem637's Avatar
    Jan 2013
    Michigan
    Default Ceramic Tile--What To Put Around Toilet Flange
    Saw this picture and was wondering after the tile is set should grout should be put in the void between the 4" stub for the toilet and the adjacent tiles or should that area be caulked?
    Thanks for your opinions and why do you prefer one way over the other?
    IF that was a job I was doing, the first thing I would do is call the tile person back and tell him to give me the proper gap around the pipe so the flange would slide down. That being the case, there would be NOTHING between the tile and the pipe until I installed the flange. Once the flange is installed, there still doesn't have to be any "filler", unless someone wants to put it in while I stand around, (on the clock), and wait for them to do it.
    Nov 2009
    Victor, MT
    They makr rings that fit inside the pipe, but you still need no filler.
    Jan 2013
    Michigan
    Why be wooried about more room on the outside of the stub when the flange is going INSIDE the 4"??
    I would consider that a poor install then because you want some filler in case of a leak. Dont want water easily getting underneath. But to each their own.
    Jan 2008
    Most of us do not plan for "in case there is a leak", as everything else we do is to ensure that it does not leak.
    The only time I ever use an inside fit flange is when replacing a broken outside fit flange.
    You can caulk it if it makes you feel better.
    quote;W hy be wooried about more room on the outside of the stub when the flange is going INSIDE the 4"??
    I guess the main reason is because i DO NOT use the "inside flanges". AND, I install the toilets so they do NOT leak.
    Jan 2013
    Michigan
    Unless you have to
    quote; Unless you have to
    The "unless you have to"s are fairly rare. The usual reason is when some dingbat pours concrete right to the riser and I don't want to spend a couple of hours drilling and chopping concrete.
    Jul 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
    Jul 2009
    North Vancouver, BC
    Jan 2013
    Michigan
    Quote Originally Posted by johnfrwhipple View Post
    The coverage of the Red Guard looks off. Not thick enough.
    1 coat top two photos
    3 coats I think bottom left photo
    Are those tiles installed our just dry fit? Please tell me they are just dry fit.
    ok they are dry fitted
    Jul 2009
    North Vancouver, BC
    Jan 2013
    Michigan
    I'm thinking your tiled floor (if set already) is a disaster waiting to happen. You should not be able to see the Ditra between the tiles when properly set.
    The tile was just laid out not set. Did you really think someone could thinset that good and not get it between the joints?? well actually thinsetting it that good to not get between the joints would really be thinsetting it bad.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    It is best to install an external flange if possible. To do that you will need a larger annular space as HJ says. Starting with an external flange gives you more options down the road if a repair is ever needed. After the external flange is installed, you can caulk up cracks at the flange but be sure to leave room for the toilet bolts.
    http://www.youtube.com/watch?v=gk6iGjKmIag
    http://www.oatey.com/products/drains...closet-flanges
  1. Tile floor: Spacing/raising ceramic tile with no heat mat underneath
    By rfsmith48 in forum Shower & bathtub Forum & Blog
    Last Post: 10-18-2012, 07:11 AM
  2. Ceramic Tile - thinset and tile gaps
    By justanotherdriftwood in forum Remodel Forum & Blog
    Last Post: 03-13-2009, 04:06 PM
  3. New Ceramic Tile/ old Toilet Flange
    By flyfishbum in forum Toilet Forum discussions
    Last Post: 03-05-2007, 07:58 PM
  4. ceramic tile under toilet flange
    By mbobden in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-16-2007, 04:37 AM
  5. No Slip Strips for Toilet on Ceramic Tile?
    By RaynLois in forum Toilet Forum discussions
    Last Post: 04-23-2006, 11:01 AM
