Thread: steel pipe problem
    DIY Junior Member kiltybob's Avatar
    Apr 2013
    milwaukee wi
    Post steel pipe problem
    I can't get steel piping off. The pipe was clogged, and deteriorated on one end, and alot of the threading came off. I used WD-40, and then a pipe wrench, but it wouldn't budge. This is located under a kitchen sink with little room to move.
    Nov 2009
    Victor, MT
    Are you talking about a drain line or the water supplies?
    If you are trying to remove a pipe nipple for the shutoff, it's going to take some muscle.
    A pipe wrench helps to break it loose, though sometimes if the pipe is crushing, you may need an easy out.
    I assume it is the drain line, and if so, you need the biggest wrench you can fit inside the cabinet and the heaviest hammer you can swing under there to "beat" on the wrench.
  1. Hole in steel pipe under tub
    By rpreheim in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-08-2008, 08:44 AM
  2. Steel to Clay Pipe connections....
    By sowatson in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-13-2008, 07:34 PM
  3. Easiest way to hook up ice maker to steel pipe
    By ga1990 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-16-2006, 07:10 PM
  4. Removing galvanized steel pipe from cast
    By jdkimes in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-20-2006, 09:10 PM
  5. Odd size steel pipe nipples
    By ej in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-12-2004, 08:25 AM
