Thread: Does regular plumber's putty stain quartz?
    DIY Junior Member PixieFix's Avatar
    Feb 2013
    Chicago
    Default Does regular plumber's putty stain quartz?
    I know it stains granite countertops but what about quartz?
    I used regular plumber's putty when I installed a soap dispenser over 6 mos ago. (This was before I came across posts on different forums saying plumber's putty stained their granite/stone countertops.) My quartz countertop did not get stained.
    If a stone material gets stained by plumber's putty, does that happen fairly soon (e.g., after a month) or does it take many many months (or year/years) before the stain appears? I have a new faucet to install but am also wondering if I should remove the soap dispenser and reinstall with non-staining plumber's putty.
    The quartz countertop is Silestone by Cosentino, if that matters.
    A resin based solid surface probably won't react like a full, natural stone would. Natural stone is rarely without minor inclusions, which can soak up the oil of some plumber's putties. The resins in the solid surface probably filled those in. No guarantees.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by PixieFix View Post
    If a stone material gets stained by plumber's putty, does that happen fairly soon...
    In my case my light coloured granite stained fairly soon. If your counter hasn't stained after 6 months, it is not likely to become a problem.
  1. is plumber's putty under plastic okay?
    By Ivory in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-18-2010, 10:46 PM
  2. Acrylic bathtub & Plumber's Putty
    By francis in forum Shower & bathtub Forum & Blog
    Last Post: 11-04-2009, 02:57 PM
  3. Do Toilet Installatoins Still Use Plumber's Putty
    By jbell94521 in forum Toilet Forum discussions
    Last Post: 10-21-2009, 09:06 AM
  4. plumber's putty - not on granite?
    By ginahoy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-24-2009, 08:49 AM
  5. Plumber's Putty swells out
    By firefly in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-07-2008, 09:26 AM
