Results 1 to 7 of 7
Thread: Adding a tub drain to a toilet branch
Threaded View
    DIY Junior Member JP's dad's Avatar
    Apr 2013
    Missouri
    Default Adding a tub drain to a toilet branch
    Starting a new thread - was told that I shouldn't add this to a thread that had already been started. I am remodeling an old 2nd floor bathroom and want to put the tub on the same branch as the toilet. See the picture below.
    I want to put the toilet between the tub and the tub drain. I was thinking of using a long sweep with a low heel inlet to connect the tub to the toilet and then the toilet to the stack. There is a separate vent line by the tub already, so that won’t be an issue. It is OK code in Kansas City. My question is whether this works well or not – I have read that if the toilet is not always at the end of a branch, low volume toilets tend not to get sufficient suction to pull waste all the way through the toilet’s trap. There really isn’t enough clearance to put a wye fitting between the closet bend itself and the stack Tee to connect the tub on the “dirty” side. Any thoughts?
  1. Branch drain sizing
    By Aaa123 in forum IPC Plumbing Code Questions
    Last Post: 02-04-2012, 08:46 AM
  2. basement drain question for adding wall hung toilet
    By Bull in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-10-2011, 06:45 AM
  3. Question on adding branch to a panel - how do you guys access the knockouts?
    By Probedude in forum Electrical Forum discussion & Blog
    Last Post: 04-27-2011, 04:16 PM
  4. basement - moving toilet drain and adding shower
    By moveright in forum Shower & bathtub Forum & Blog
    Last Post: 12-01-2009, 03:41 PM
  5. Adding bathroom back to back with existing - share 3 inch branch?
    By mturse in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-04-2008, 07:25 AM
