Page 2 of 2 FirstFirst 12
Results 16 to 21 of 21
Thread: Testing Pressure Tank
  1. #16
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    Everything you need is readily available at any plumbing/pump supply house in Danbury
  2. #17
    Residential Design and Consultant knowhow's Avatar
    Aug 2007
    Fairfield, Connecticut
    Quote Originally Posted by craigpump View Post
    Hey craigpump,
    Thanks for your replies. Where are you located?
    I was wondering if you would give me your opinion?
    I have another thread going over at the water softener forum here if you care to chime in
    http://www.terrylove.com/forums/showthread.php?51493-sizing-new-pressure-tank-and-CSV-for-use-with-Clack-air-injector-prior-to-softner
  3. #18
    Aug 2007
    I think you misunderstand what I'm saying, we have seen iron build ups inside the liner on Amtrol tanks, which then reduces the drawdown capacity of the tank. The only time I have seen iron on the air side of the diaphragm is when the diaphram has failed.
    I'm not a treatment guy by any means, but he has to deal with iron issue before he puts in a new tank or eventually the same issue will occur. I have seen guys install a short 42 gallon galvanized tank before the Amtrol with a micronizer before the galvanized tank. They plumb the inlet into the middle port and take water out the top of the tank over to the tank T on the Amtrol. Their theory is that the iron will drop out in the galvanized tank which can then be drained off. I personally have never done it.
    As for tone LL, I only give back what I feel I am being given.
    craigpump,
    I'm sorry I did not read this reply in its entirety earlier.
    This seems like a relatively simple solution to keep the iron from gunking up the P tank..
    I wonder if I could use the retention/contact tank Gary Slusser was talking about http://www.apwinc.com/retention_tank.html, at this position in the componentry sequence.
    Or, possibly the Wellmate (UT-40) tank which "LLigetfa" suggested I consider.
    Both of those tanks seem to be able to be drained easily. I don't know which would work better at this location ie. restrict the flow less.
  4. #19
    Apr 2012
    ct
    I know just enough about treatment to get into trouble. I can recommend a few guys here in Fairfield County that really know their stuff though
  5. #20
    Aug 2007
    That would be great, I'd appreciate it.
  6. #21
    Apr 2012
    ct
    Check your notifications
  1. Natural gas valve pressure ratings and pressure testing
    By pigrew in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-29-2013, 03:42 PM
  2. WX202 Pressure Tank testing question
    By conductor in forum Pumps and Tanks Well Forum & Blog
    Last Post: 05-03-2011, 06:54 AM
  3. Pressure Testing Gas Line
    By cloves in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-16-2010, 08:33 PM
  4. Oil tank testing- can you help me?
    By flamefix in forum Boiler Forum
    Last Post: 09-16-2009, 02:51 PM
  5. Pressure testing DWV
    By jar546 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-22-2008, 04:04 PM
