Results 1 to 4 of 4
Thread: Setting D/T on primary
Threaded View
    DIY Member tom3holer's Avatar
    Mar 2013
    Cape Cod
    Default Setting D/T on primary
    I am having a little problem trying to decide how to properly set the primary D/T on a P/S plumbed boiler. I replaced the primary pump on the Alpine 80 with a Taco Bumblebee as the pump curve showed it matched very closely what I was looking for. I wanted to get a 35* D/T across the boiler so as to maximize efficiency. The bumblebee's flow indicator is WAY off. It should be in the range of 4.2GPM when set the constant speed #2, which it is. The flow indicates 9.8GPM. My confusion comes from how to set the primary D/T when set to high fire in reguards to the zones. Should all zones be running or not?
    Thanks,
    Tom
  1. Do I need a primary loop? (Lochinvar Knight)
    By dwassner in forum Boiler Forum
    Last Post: 04-27-2013, 05:26 AM
  2. what does setting the Grain per gallons acually do when changed to different setting
    By sirleaky in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-17-2012, 07:14 AM
  3. Oil burner primary control.
    By jocko in forum HVAC Heating & Cooling
    Last Post: 02-27-2009, 01:36 PM
  4. Sump: confused - need primary and backup.
    By Rather-Be-Boating in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-09-2009, 08:34 AM
  5. Main lug as a primary service panel
    By madpenguin in forum Electrical Forum discussion & Blog
    Last Post: 01-06-2008, 07:52 AM
