Results 1 to 3 of 3
Thread: Crane plumbing rear outlet toilet - need to replace wax ring
    DIY Junior Member joseph a's Avatar
    Apr 2013
    Chicago
    Default Crane plumbing rear outlet toilet - need to replace wax ring
    My condo has a crane plumbing rear outlet toilet and I need to replace the wax ring. I'd like some guidance on picking the right replacement part.
    I've read that rear outlet toilets require a felt - wax ring or a neoprene ring, etc... Can anyone provide guidance on which of these options is best, or the positives/negatives of each? I does appear that neoprene rings are more expensive. Are they worth the added cost?
    Thanks much!
    From what I've read, wax isn't a good choice for a rear-outlet toilet. Now, I've never dealt with one. On a floor, it works fine since it is a single plane; the toilet sits on the floor, but must seal to a wall that could move independently...you want something that's resilient...wax, once it gets compressed, doesn't spring back.
    DIY Member wallskev's Avatar
    May 2009
    North Carolina,USA
    See previous posts;
    http://www.terrylove.com/forums/show...t-seal-options
    Always search for answers first.
    Kevin
  1. What is the best rear outlet toilet to date?
    By flyingpiglet in forum Toilet Forum discussions
    Last Post: 12-06-2011, 04:39 PM
  2. rear outlet toilet install
    By potterboy1 in forum Toilet Forum discussions
    Last Post: 09-27-2010, 06:01 PM
  3. wax/neoprene ring for rear outlet/wall toilet
    By Reno3 in forum Toilet Forum discussions
    Last Post: 03-18-2007, 11:47 AM
  4. AS Yorkville rear outlet toilet
    Last Post: 03-14-2007, 08:49 AM
  5. rear outlet toilet
    By Dra in forum Toilet Forum discussions
    Last Post: 01-29-2007, 03:36 PM
