Results 1 to 6 of 6
Thread: Washer Supply Fittings Loose
    DIY Junior Member index1489's Avatar
    Mar 2012
    CA
    Default Washer Supply Fittings Loose
    Just had a new washer/dryer installed, during the installation I noticed when the installer tightened the new hoses on the water supply outlets, both outlets rotated slightly 20-30 degrees. I assumed these were sweat fittings and shouldn't be able to rotate like that.
    Grabbing the hose I can get both outlets to rotate in each direction 20-30 degrees, is this normal?
    The supply box is from IPScorp "Water-Tite" looks like this one.
    http://www.ipscorp.com/plumbing/wate...gmachine/duall
    Place was built 2005-2006.
    Had the previous washer installed for over a year with no issues, this one for a couple of days again no issues noticed yet.
    Photos attached
    Yakima WA
    Looks like the connectors are made to swivel.
    quote; Looks like the connectors are made to swivel.
    NEVER!! If it was installed with plastic water pipes, or a "Sharkbite" connection, it will "wiggle" if the lock nut underneath loosened up.
    Yakima WA
    My bad! Thanks HJ, you got me again!
    Mar 2012
    CA
    So it this something I should worry about or leave alone? Couple other people have told me if its a PEX connection it could move a little and be fine.
    "That a/w books looks correct to me , sometimes they move and sometimes they don't. As long as it not leaking, you'll be fine. I used to put hundreds of those in when I work new construction. Water-tite brand moves and others do or don't as well"
    "If I'm not mistaken, built in 06 would be pex. If that's the case, I wouldn't worry about them rotating, just keep your eye on them. I know shark bites you can move and they're still"
    "You could also have CPVC pipe. CPVC and Pex could rotate a bit but be careful you can damage the piping in the wall causing a water leak. Just a bit of advice, I would change the cold water hose to a stainless breaded also."
    Seems odd I know I have copper in the bathrooms when I replaced a couple of cartridges, is it common to mix PEX and copper in the same house?
    You probably have a PEX system with copper connections to the faucets.
  1. Washer Supply Pipe Size Question
    By jdubt in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-09-2013, 09:37 AM
  2. Faucet was loose and moved a bit...Are my compression fittings OK?
    By tfm825 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 08-24-2012, 11:08 PM
  3. Add Sink Beside Washer and Move Supply Valves
    By monkeystomach in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-09-2011, 09:51 AM
  4. Loose Sweat Fittings
    By rdtompki in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-17-2010, 07:18 AM
  5. leaking compression fittings on supply valves
    By emptyb in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2005, 01:03 PM
