Results 1 to 2 of 2
Thread: No water second floor,help!
    DIY Junior Member tiffkbjf's Avatar
    Apr 2013
    chicago
    Default No water second floor,help!
    I purchase a forclosure. I recently turned on the water. The first floor seems fine dispite the toilet problems. The second floor however isnt getting any water, toilet, sink, nothing. Its a multi unit. Ive turned on every basement valve. What else is there?
    There may be an additional valve somewhere upstairs. This would be desirable to be able to service it without impacting the first floor tenant. Maybe in a utility room, behind a panel, in a closet...hard to say. The other, much more problematic, is that maybe during the winter, the heat was off, the pipe split, and it's running in the wall(s) somewhere. With everything off, check the water meter (assuming you have one) and see if it is registering any water flow. If it is, shut off the main, then go searching!
