Page 4 of 4 FirstFirst 1234
Results 46 to 56 of 56
Thread: sizing new pressure tank and CSV for use with Clack air injector prior to softner
  1. #46
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by knowhow View Post
    Deadhead? What does that mean?
    Sorry to throw so many details at you. If the head on a pump exceeds its capability to move water, it will deadhead. At some point it cannot move more water so cannot make more pressure above its designed head. When it deadheads, it just heats the water in the pump.
    Early on in one of your threads, I suggested that you plot the curve of your pump. That will tell you how many GPM the pump can produce at what PSI. The PSI is the artificial head. The real head is the level of water in the well. the injector can also add some head.
  2. #47
    Residential Design and Consultant knowhow's Avatar
    Aug 2007
    Fairfield, Connecticut
    I don't know how much iron you have to begin with nor do I know what percentage of the pump cycle your injector draws air or how much air. Most injector makers say that they need to draw air for at least half of the pump cycle. Then the water from the other half of the cycle needs to co-mingle with the aerated water in the retention tank for a period of at least 2 minutes, so the flow rate is a factor.
    My 30 gallon precipitation tank has a drawdown capacity of 6.6 gallons but the total water capacity I'm unsure of. It tops out at about half-full so that could be 15 gallons. Some day I should measure it. So, if I draw off 6.6 gallons from 15, that would be 8.4 on the low side. Worst case, 2 minutes of contact time would mean a flow rate of 4.2 GPM if my math is right.
    Gary tells me that I don't have enough contact time, that I should use a contact tank with a top exit. I have some iron bleed through my iron filter to my softener which fouls the resin. I've taken a water sample after the iron filter to my dealer for testing and he could not detect any iron so either none bled through at the time I drew the sample or his test failed to detect it. I read that some tests don't detect ferric, only ferrous iron.
    The amount of iron in my water would clog an element type filter quickly.
    I'm sorry. All of this makes total sense. So, I see your point about the spin down filter being useless at this location.
    My last water test showed 0.19 mg/L
    I understand that I could and should build a more effective system. I can't afford to do so at this time.
    I thought there might be a less expensive, simpler solution.
  3. #48
    Aug 2007
    Dang, missed that Q as well. Think of the precipitation process kind of like making butter. It takes time for the tiny particles to glob together.
    I did not realize that. I just thought that once it was oxidized it became filterable.
  4. #49
    Aug 2007
    Yes, I printed that reply and was going to test for that info, but thought the outcome would be incorrect because of the current state of my system.
    The Bad P tank.
    I'd really like to know what GPM my pump can produce both with and without the injector.
    Do you think I can still plot a true pump curve with a malfunctioning P tank?
  5. #50
    Aug 2007
    off topic question
    how are you able to quote just a portion of someones reply?
  6. #51
    Feb 2011
    NW Ontario, Canada
    When plotting the curve, the water is neither going into, nor leaving the tank so the condition of the tank is not a factor.
  7. #52
    Feb 2011
    NW Ontario, Canada
    I delete what I don't want to quote from in between the [QUOTE] tags.
  8. #53
    Moderator valveman's Avatar
    Mar 2006
    Lubbock, Texas
    Just catching up. My opinion, for what its worth? I would not use a CSV unless you change to a system like the Sulfur Eliminator that does its thing in the well. If you have to inject air after the pump, I would not use a CSV, and would not have a bladder tank first thing after the injector. I think when you pull the old bladder tank out, you will see it is plugged up as LL says, and you won’t want to go back the same way.
  9. #54
    Aug 2007
    Quote Originally Posted by valveman View Post
    Thanks for your opinion valveman.
    I will be installing a new 81 gallon Well-x-trol with my plumber, in the next day or two.
    I've ordered the Sulfur Eliminator Deluxe from Mitch and will hook it up when I receive it. He was very helpful and took the time to answer all my questions.
    He modified the unit to work with my application since I will be testing it before permanently installing it.
    BTW, for others reading this, I do not have a Sulfur problem, I am using it to address the Iron in my water.
    He said I would need to adjust it to do heavy aeration for the first week or so, monitor the filter it comes with and change it out.
    I'll be removing the existing Clack air injector, which precedes the new pressure tank, and will be temporarily replacing it with a (4 x 10) 30 micron inline filter.
    The GE filter is rated at 10 GPM, my well pump produces approx. 10 GPM, so I don't expect it to restrict the flow very much.
    The reason for the addition of the inline filter is because the Sulfur Eliminator is expected to clean up iron deposits on the well casing and "stir up" stagnant water, so I need to prevent most of that gunk from entering my system. It will be interesting to monitor the inline filter to see if the sediment gradually declines as the well gets cleaned up. Temporarily, the supply water for the Eliminator will be from an exterior spigot, near my well head, which is post pressure tank. Hopefully it will work as claimed and I will install a spigot (hydrant?) on the main line near the well cap prior to the pressure tank. Then I'll be talking to you about a CSV.
    I am considering ordering a Hach Iron test kit (IR-18A) to better analyze the performance of the Eliminator over my existing air injector system.
    If for some reason this fails to address my Iron issues then I will be considering the other options suggested.
    BTW, Mitch said if it doesn't work, then send it back.
  10. #55
    Feb 2011
    NW Ontario, Canada
    I wish iron filter manufacturers came with a money back guarantee. I'm sure that I have way too much iron for the Sulphur Eliminator. Unfortunately my dealer doesn't have a test kit (nor do I) that works with iron after it has gone through aeration.
    My dealer is trying to sell me on an Excalibur iron filter so that I can eliminate the air injection that robs me of pressure and flow. I tried to get technical documents on how they do the aeration without the inherent problems that my micronizer has. What I got was an explanation in an email reply instead. Purportedly, they use only the backwash cycle to inject the air, not the service mode. They then spray the water through the captured air during the service mode, replenishing the air on the next backwash cycle. I still have concerns about contact time, since it is done immediately before the filter media.
  11. #56
    Aug 2007
    It isn't really a money back guarantee, but they gave me 30 days to try it out.
    How much Iron do you have?
    Hach has a variety of Iron test kits, all except one are for Ferric Iron (post oxidation) the choice of kits depends on the amount of Iron you want to test for.
    http://www.hach.com/metal-in-water-test-kits/category-products?productCategoryId=14371222290&secondPageN umber=1&pimContext=USen
    Why not give Excalibur a call directly and ask to speak to their tech dept., looks like they're in your neck of the woods. Here's the link to their Iron filters and there's a link for their contact info there http://www.excaliburwater.com/iron_sulphur_filters_residential.htm . I actually just gave them a call and spoke with Sam who seemed very knowledgeable. They use the Clack (air injection) valve.
    I have been looking at the Fleck AIO (air injection) valves, as an alternative to my current system. I was/am considering using one of their valves, either the 5600SXT AIO or the 2510 SXT AIO as a substitute for the 5600 basic valve on my current pH neut tank setup, as a way to oxidize the Iron post pressure tank versus before it, as I do now with the Clack injector. I would probably need to replace the tank with a larger one for some aerospace. I spoke with a teck at Fleck to ask if I could simply reconfigure my existing valve. He said I should call and ask the inventor and gave me his phone number. This all started (my search for iron removal options) because many say I shouldn't use the injector before a bladder type P tank. BTW, personally, for my Iron content, I think it would be fine to use the air injector prior to the P tank as long as one would drain it down to flush out any iron sediment regularly, say quarterly. Unfortunately, I did not know that I needed to clean my P tank that often. It was on it's last legs anyway. It lasted 20 years, and I installed the injector 5 years ago.
    I am hoping that the Sufur Eliminator Deluxe (SED) will work for my minimal? 0.19 mg/L of Iron, because I would like the option of using a CSV with my system for summer lawn watering and valveman has stated that I can't use their CSV with an inline air injector. One downside of the SED, is that I will need to monitor its inline filter which will be located outside in my well head containment area, which will mean removing 3-4" of dirt/mulch, lifting a 2" x 36" diameter concrete lid and jumping down into a 3'-0" deep pit, annually . The other downside is that it constantly runs at 1.5? GPH to do its job recirculating the aerated water it makes. The other downside is the cost for that little deluxe contraption.
    I'm still waiting for my plumber to come help install my new P tank. Hope my well pump hangs in there.
    After the new P tank install I will test for Iron with my current setup (injector pre P tank) and then I'll do the SED temporary install and will monitor the Iron. Then I will have the pH neut tank valve and softener valve serviced by a newly referred company.
    I have purchased (as advised by dittohead) new, correctly sized, parts for my Fleck 7000 softener valve to replace the incorrectly sized ones in my 5 year old softener and will adjust (per dittohead and others) the salt settings for better efficiency.
  1. Sizing a new well pressure tank.
    By cwilliams2000 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-25-2013, 05:14 AM
  2. Well pump shuts off prior to pressure switch cutoff
    By ABrown in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-26-2012, 05:43 AM
  3. Sizing a new Softner System
    By Phillbo in forum Water Softener Forum, problems, installation and reviews
    Last Post: 02-22-2011, 07:18 AM
  4. New member's questions. pressure tank sizing
    By DeeJay in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-20-2010, 02:08 PM
  5. Pressure Tank Sizing/Replacement
    By dcav6809 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-19-2008, 07:50 AM
