Results 1 to 5 of 5
Thread: Help with strange light fixture wiring
    DIY Junior Member teddy12's Avatar
    Apr 2013
    Richmond, VA
    Default Help with strange light fixture wiring
    Hello All,
    First-time poster here and looking forward to becoming a part of the community here. I have a need for help with a strange wiring situation in my bathroom. I have attached the following image which is crudely drawn, so I apologize. Assume there is a ground wire in all sections of this diagram. I have a neutral and hot 14 gauge wire coming into a wall switch. The output of that switch is neutral, hot, and red wires. The red wire receives the current when the switch is on and the black hot coming into the switch simply wraps around the other screw and gets capped with the black wire that continues up into the ceiling. In the ceiling box previously, the red went to the hot screw of the light fixture, the black wire got capped with the black wire that continue on through the circuit, and the neutral white had a section cut out of it, was wrapped around the fixture's other screw and then was capped with the white wire that continued on through the circuit. My question is:
    The new light fixture I have has two bulbs and has two whites and two blacks coming out of it. Knowing that the red was the hot when the switch was on, I capped the red together with the two blacks from the fixture. For the two whites, I capped one with the incoming white ceiling wire and one with the outgoing white ceiling wire. When I turn the circuit on and the switch is off, both bulbs glow faintly. When I turn the switch ON, only one bulb glows brightly. Can somebody tell me what I am doing so terribly wrong here? I have just never run into this situation before. The red (as far as I know) is not part of a multi switch setup and may have been part of a fan/smoke detector setup. I appreciate the help in advance if anyone can lend it.
    -Ted
    DIY Member Stuff's Avatar
    Mar 2013
    Pennsylvania
    All four of the whites need capped together at the fixture.
    Jun 2007
    North Carolina
    Quote Originally Posted by Stuff View Post
    Yes .
    Apr 2013
    Richmond, VA
    Thank you guys - will try that approach tonight and now that I read that out loud, it makes perfect sense and I'm not sure why I didn't try that first.
    Appreciate the help and hope to become a helpful contributor here.
    -Ted
    When the switch is off, you are using the bulbs as part of the circuit's neutral wiring, (the hot which is off at the time, is being used as a "shunt" between the two neutrals, causing the bulbs to glow), which should serious impact on whatever is farther down the line on that circuit. When the switch is turned on, it negates the shunt to the "broken" neutral, so only the one bulb works properly.
  1. DIY - Split receptacle to light switch and light fixture with 14/2?
    By AJM in forum Electrical Forum discussion & Blog
    Last Post: 11-24-2009, 04:36 PM
  2. bathroom light fixture
    By rburt5 in forum Shower & bathtub Forum & Blog
    Last Post: 03-21-2009, 06:53 AM
  3. Light fixture above the shower
    By Dexter in forum Shower & bathtub Forum & Blog
    Last Post: 09-29-2008, 06:37 PM
  4. Strange architectural lighting wiring
    By Backglass in forum Electrical Forum discussion & Blog
    Last Post: 01-21-2008, 03:25 PM
  5. Ungrounded light fixture
    By maddfrog in forum Electrical Forum discussion & Blog
    Last Post: 12-01-2007, 11:51 AM
