Results 1 to 4 of 4
Thread: Wet Vent Drain Sink Into Toilet 3" Vent or Add Elbows to a Vent
Hybrid View
    DIY Junior Member remodel4ever's Avatar
    Apr 2013
    Austin, TX
    Default Wet Vent Drain Sink Into Toilet 3" Vent or Add Elbows to a Vent
    This is a remodel of a 2nd floor bathroom. Original plumbing is hubbed cast iron and screwed steel. Mods will be made in PVC, with tie-in by screw and/or no-hub compression couplings.
    Looking at the wet wall from left to right I have the 4" iron main stack, existing sink drain, 3" screw pipe vent for downstairs toilet. Vent is commoned back to the main stack at about 4" height.
    The sink drain currently runs laterally into the main stack. The sink drain location is moving to the right of the 3" vent. Should I consider draining the sink into the 3" downstairs toilet vent? Or should I add elbows to the 3" vent and dog-leg it around under the new sink drain location? I understand a wet vent spanning floors would not be to code, probably for good reason. How bad is adding two, or possibly four elbows to bend the 3" toilet vent around the new drain location? Is 4 elbows in the vent ok? It would simplify the cutting and splicing.
    It is probably a 2" steel pipe, because no plumber would work with 3" screwed pipe in a residence. You can offset a vent with as many elbows as necessary, or as many as you want to use.
    Apr 2013
    Austin, TX
    It is 3" screwed steel pipe in a residence, built in 1963. Along with the 2" screwed pipe. Along with the 4" and 2" hubbed iron pipe. Lots of variety.
    Excellent to hear I can offset the vent with multiple elbows. Thanks much!
    Jan 2008
    As long as the bends in the vent will not trap any incoming rainwater or condensation, you are golden.
  1. Can a 2" DWV WC vent also be used to vent a 1-1/2" basin drain?
    By bergmanj in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-30-2012, 07:45 AM
  2. Can you tie lav drain into a toilet vent (wet vent)? W/SKETCH
    By kmuddzy in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-27-2012, 10:15 AM
  3. Sink and Toilet Drain Vent Questions
    By kmoe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2011, 09:40 AM
  4. layout for toilet/floor-drain/sink & sizing vent
    By Eliot in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-17-2009, 04:34 PM
  5. Island style vent for bathroom sink vent?
    By rvportland in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-16-2006, 08:34 PM
