Results 1 to 5 of 5
Thread: What's the most reliable way to go from copper to pex without soldering?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default What's the most reliable way to go from copper to pex without soldering?
    Just curious to hear what you think is the best way to go! I know a lot of people wouldn't consider not soldering, though.
    I normally solder on a PEX adapter to copper pipe.
    However if you're not soldering, then you are looking at a sharkbite.
    DIY Junior Member teddy12's Avatar
    Apr 2013
    Richmond, VA
    Been very happy with my SharkBite adapters so far. Are you not trying to solder because of tight spacing or things nearby?
    Mar 2013
    Here
    To be honest, I have none of the stuff required and it's gonna be kind of expensive. That, and I have no experience soldering, and I want to get this project done. Thanks for all the info!
    Yakima WA
    Basic soldering "stuff" is not expensive. All you need is a propane torch, a can of flux, a tubing cutter, a roll of solder, and a roll of emery cloth or brushes to clean the pipe ends and fittings. Sweating joints is not a difficult skill to learn, even if your first efforts don't look pretty, they will work. A few practice fittings and a little pipe is all you need to learn.
  1. Copper to pex without soldering?
    By amateurplumber1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-22-2013, 07:55 AM
  2. Reliable Tub/Drain Overflow Units - Which brands are reliable
    By chefwong in forum Shower & bathtub Forum & Blog
    Last Post: 06-15-2011, 05:20 PM
  3. Soldering.. copper to copper OR copper to brass.. which one?
    By lithnights in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-02-2010, 05:15 AM
  4. soldering soft copper
    By scott99 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-07-2007, 03:13 PM
  5. soldering copper pipe
    By gink in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-05-2005, 07:26 PM
