Results 1 to 2 of 2
Thread: Twisted valve body on Delta Monitor shower faucet
    DIY Junior Member cowboyshoes's Avatar
    Apr 2013
    Minnesota
    Default Twisted valve body on Delta Monitor shower faucet
    I recently replaced the cartridge on a Delta Monitor 1700 series shower faucet. During the process I encountered a brass nut that was severely stuck on the valve body and prevented me from removing cartridge. I Goggled it and came across the following thread on this forum:
    http://www.terrylove.com/forums/show...ace-cartridge!
    In summary, the advice in the thread tells you to use two wrenches, one on the valve body to hold it in place and one on the nut. Then heat the nut to remove it. However, against my better judgement I attempted this fix myself, heating the nut but just using one wrench to loosen it. I didn't have a 2nd set of hands with a wrench on the valve body to hold it in place.
    I managed to remove the brass nut, but it resulted in the valve body getting rotated slightly counter clockwise:
    Everything is working great with the shower now, no more leaks, but I'm worried that I may have caused some permanent damage. I'm looking for advice to determine whether I've damaged the valve body and what detrimental effects I may have caused (leaking? potential for valve bursting down the road when I'm off on vacation??)
    Sometimes it moves the copper tubing behind and leaves a twist like that. Copper will bend. I've seen plenty that have been worked on in that condition that are still in service.
  1. Delta 1500 Series Monitor shower head etc
    By stuckwitholddelta in forum Shower & bathtub Forum & Blog
    Last Post: 05-28-2013, 10:00 AM
  2. Delta R10000-UNBXHF Multichoice Universal Shower Only Valve Body
    By themp in forum Shower & bathtub Forum & Blog
    Last Post: 03-13-2013, 04:29 PM
  3. Replies: 6
    Last Post: 06-07-2011, 01:26 PM
  4. delta shower valve body - no water
    By jrburt in forum Shower & bathtub Forum & Blog
    Last Post: 05-21-2008, 04:56 PM
  5. Delta Monitor 1700 Valve question
    By elgato in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-25-2007, 07:07 AM
