Results 1 to 8 of 8
Thread: Thinset expiration dates
    DIY Member SH140's Avatar
    Jan 2013
    Vallejo, Ca.
    Default Thinset expiration dates
    I've seen posts saying not to use thinsets that are more than a year old (date on container). Why is this, and what would happen if you did use older material? I recently purchased 4 bags of Laticrete (3 of 255, & 1 of 272) and couldn't find the date until I got home. The date marked on bags is April 2011.......Now what?
    __________________
    Steve
    Jul 2009
    North Vancouver, BC
    Default Checking date codes on Laticrete bags
    That thin-set is garbage. Do not use it at all.
    We try and not use any thin-set older than 3-6 months.
    I to recently bought an expired bag of Laticrete thin-set. It's in the truck ready to return to the place I bought it from.
    Laticrete makes the best packaging in the business but two year old thin-set will be nothing more than sand once mixed.
    Send it back.
    If you get any grief over it call up LAticrete Customer Service and they will set the seller straight.
    Often product gets poorly shuffled in a warehouse and this could be the result of this. Or a savy warehouse manager was trying to pass off dated product on you.
    Either way your out the trouble to go back and switch it.
    Sorry.
    ALWAY CHECK THE DATE CODES BEFORE LEAVING A STORE!!!!
    This is one of my own rules and I broke it just three weeks ago. And read the bags - often there are primers or other liquids these products detail for slurry coats or unique installs.
    You can find the local Laticrete offices here and look up their phone number. http://www.laticrete.com/contact_us.aspx
    JW
    Quote Originally Posted by SH140 View Post
    __________________
    Steve
    Jul 2009
    North Vancouver, BC
    Default Saving a failed installation
    If it helps any - the simple fact you checked this out most likely saved the installation from failure or from being less than perfect.
    The portland cement in thin-set absorbs moisture from the air causing it to set up before mixing. This results in a thin-set with little to no strength.
    Good on you for checking.
    TWO THUMBS WAY UP!!!
    JW
    Jul 2009
    North Vancouver, BC
    The bags of Laticrete setting materials are clearly marked on the top. Easy to read and follow.
    Now checking Mapei and Ardex bags can be a nightmare. I have decoded much of the Mapei code and have it outline here.
    The Ardex codes I'm still working on.
    Always ask this question and always check.
    If you see a Mapei Code that looks like this D14H204 503
    To figure out the code you need to do this;
    D = Vancouver
    14 = Day of month
    H = August
    2 = 2012
    04 = Batch number
    503 = Still not sure. Not even the help desk at Mapei knew what that meant.
    Mapei produces product all around Canada and the US. You can clearly see in the picture that this was made in Canada. Personally I would have used a "V" for Vancouver but there must be some other system going on at Mapei head office.
    Example: If this was made at Mapei's Brampton plant on the same day it would have had an "I" instead of a "D" so the date code would have been I14H2** --- (** = what batch number they are working on)
    Example: If this was made at Mapei's Laval plant on the same day it would have had an "L" instead of a "D" so the date code would have been L14H2** --- (** = what batch number they are working on)
    Mapei - Canadian Letter Codes for manufacturing plants
    D = Vancouver
    I = Brampton
    L = Laval
    Mapei - American Letter Codes for manufacturing plants
    J = Chicago
    The "H" code is for August. The letters are in ascending order so the month codes are as follows
    A = JANUARY
    B = FEBRUARY
    C = MARCH
    D = APRIL
    E = MAY
    F = JUNE
    G = JULY
    H = AUGUST
    I = SEPTEMBER
    J = OCTOBER
    K = NOVEMBER
    L = DECEMBER
    the digit after the month is the last digit in the year. "2" for 2012.
    D = Vancouver (Delta), B.C.
    I = Toronto (Brampton), Ontario
    ? = Calgary, Alberta
    A = Laval, Quebec
    L = Fredericksburg, Virginia
    S = San Bernardino, California
    E = South River, New Jersey
    F = Ft. Lauderdale - (Deerfield Beach), Florida
    G = Garland, Texas
    C = Tempe, Arizona
    J = West Chicago, Illinois
    ? = Caracas, Venezuela
    Jan 2013
    Vallejo, Ca.
    I'm wondering, would you be able to feel a difference in the bag (like it's one solid block) if it's expired? The one's I bought seem to feel like I imagine they should ( loose and soft).
    Jan 2008
    I like to think of it like expired food in the refrigerator. It might still be good, or it might tear your guts out for the next week or so.
    I'd rather throw it away and not take the chance.
    Unfortunately, old thinset often doesn't look much of any different. Because moisture comes in so slowly, often what you end up with is grains of cured cement. Because they didn't get fully wet, they don't bond together, but once cement has cured, it's basically inert. If there's enough left that's uncured, it might hold together, but it will not have anywhere near the stated strength.
    Jul 2009
    North Vancouver, BC
    The data or info on the subject of how much a thin-set weakens over time is yet another interesting thing that could be tested. Our worst failure was from some old self levelling product about 8 years ago. Complete failure. Had to rip out the entire floor and do it over (After we set and grouted the floor).
    It's rare that I see any thin-sets that are past their good to go date - next time I find a bag I'll bring it home and test it side by side with a fresh package. I think this will interesting observation.
    I'll use the same procedure for testing the thin-set as I'm using for the Spider Web testing.
  1. Thinset Thickness
    By cjt in forum Shower & bathtub Forum & Blog
    Last Post: 12-04-2013, 07:25 AM
  2. Thinset depth?
    By Ghost 60 in forum Remodel Forum & Blog
    Last Post: 04-14-2009, 08:33 AM
  3. Not sure I have the right Thinset, thoughts?
    By jpb116 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-07-2008, 06:52 AM
  4. thinset error
    By paul730 in forum Remodel Forum & Blog
    Last Post: 01-03-2006, 04:57 PM
  5. dumb thinset question
    By Richard S in forum Remodel Forum & Blog
    Last Post: 03-01-2005, 08:24 PM
