Results 1 to 9 of 9
Thread: Water pressure low. Will a plumbing company be able to trouble shoot?
    DIY Junior Member NotsoDIY's Avatar
    Feb 2013
    California
    Default Water pressure low. Will a plumbing company be able to trouble shoot?
    Actually I've had this problem since I bought the house(09). At first I thought I might need to replace the water pump but I went through the search function and I've read that it could be to simply change the pressure switch? Either way, the water pressure inside my house is awful. The gauge typically reads between 30-40psi and from what I've read in the search function, going up to 50psi would be pretty adequate.
    P.S. I've also been told that raising the psi can bust a pipe underground so if someone could confirm please.
    DIY Senior Member craigpump's Avatar
    Apr 2012
    ct
    You wouldn't hire an electrician to do your roof, so why hire a plumber to work on your well/pump?
    Seriously, the cause of your low pressure could be many things, all of which have been discussed time and again on this forum. If you don't feel comfortable working on the system yourself, hire a licensed, insured, reputable pump company.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by NotsoDIY View Post
    I don't know of any underground pipe used for domestic water that would have such a low burst pressure. Provided the pump is capable of it, 80 PSI is a normal high pressure.
    I use 160 PSI poly pipe between the pump and the house.
    Apr 2012
    ct
    I have seen plenty of old 75 & 80 psi poly used years ago in jet systems fail. The old poly was no where as good as today's material and will fail eventually.
    Feb 2013
    California
    I'll specifically search for a pump company I thought plumbing companies would be able to help.
    Feb 2011
    NW Ontario, Canada
    Quote Originally Posted by craigpump View Post
    Seriously? People cheap out and use poly designed for sprinklers? I say they get what they deserve. Even so, 75/80 PSI poly should have a burst pressure much higher than the rated pressure.
    Apr 2012
    ct
    Yeah dead serious. Back before submersibles were reliable, jet pumps were the hot ticket and there are plenty of those old systems around. The pipe gets old and fails or the system gets converted to a submersible and problems arise. The lighter pipe was used so the jet would hang straighter in the well along with getting the pipe to lay flatter in the trench.
    In the Trades Texas Wellman's Avatar
    Feb 2010
    SE Texas-Coastal
    They don't sell anything but 80 or 100 psi poly pipe here. Look it up on any lowes/HD site and type in any Tx Zipcode.
    I've seen so much poly pipe split I still have nightmares about all the digging we had to do to fix the stuff.
    Apr 2012
    ct
    Only 80 & 100 psi? What about the pump supply houses? I like 100 psi for wire conduit in the trench, but I always use 160 for the water, if the trench is boney, though ledge or under a driveway we sleeve it through 4" sch 40.
  1. Trouble with bathroom sink plumbing - s-shape???? Need help fast!
    By nole01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-22-2010, 06:06 PM
  2. Starting a website for my Plumbing Company, thoughts?
    By qrpike in forum Computers and Stuff
    Last Post: 03-11-2009, 03:11 PM
  3. Best way to market your plumbing company
    By Webber88 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-16-2008, 09:02 AM
  4. Are Reliance hot water heaters a sub-company of Whirlpool?
    By Marty 1 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-15-2008, 03:15 PM
  5. How to Trouble shoot this???
    By Carl Simmo in forum Electrical Forum discussion & Blog
    Last Post: 10-03-2007, 09:45 AM
