Thread: Reusing wax ring.
    DIY Junior Member kozak's Avatar
    Apr 2013
    minnesota
    Default Reusing wax ring.
    So basically I had a very bad clog in my toilet, the plunger and the plumbers snake both failed to resolve the issue and I was forced to lift the toilet and attempt to clear it from the other end. I succeeded in clearing the clog and put the toilet back in its place. However since this was the first time I have done this I had no idea that the wax ring generally needs to be changed after lifting the toilet, so of course i never replaced it. Now although everything seems to be working fine and I see neither leaks nor dampness around the toilet, and I don't really want to buy a wax ring and lift it again in fear that I will screw up the installation and create a leak where there is not one now. On the other hand I don't want any secret leaks to create issues for my neighbors downstairs.
    So I guess I am wondering if it is possible for a toilet to be leaking around the wax ring without any noticeable moisture around the toilet, and if so how likely is such a scenario?
    Thanks in advance.
    Because the horn on the outlet of the toilet is usually a fair amount smaller than the ID of the toilet flange, unless there's a clog, it just acts like a funnel, and you may never notice a water leak until the line clogs again. BUT, because the trap of a toilet is internal to the toilet, it CAN leak sewer gasses. So, yes, you should buy a new wax ring. Now, to complicate things a little, there are a few reusable toilet seals - from a closed-cell foam ring to funnels with O-rings that could be used and reused. Wax is a lot cheaper, and works well, but only once!
    Apr 2013
    minnesota
    I see, so unless there is a clog and I see water leaking, I can reasonably assume that I am not "drowning" my neighbors, but I can expect some odor. I kind of figured that replacement is likely inevitable but would it be safer to say that its not urgent?
    Apr 2012
    New York, NY
    Personally, it would bother me enough that I would just pull the toilet and fix it. Having recently done an install, your skills are still fresh, and I'm sure you could knock it out pretty quickly...
  1. Switching Drain Fields Question Soggy new one vs reusing old one
    By astronomer25 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-06-2010, 11:42 AM
  2. reusing antique overflow coverplate with new drain?
    By allifountain in forum Shower & bathtub Forum & Blog
    Last Post: 11-16-2006, 03:43 AM
  3. Reusing ball valve
    By ToolsRMe in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2006, 08:18 PM
  4. wax ring
    By brian44 in forum Toilet Forum discussions
    Last Post: 09-09-2005, 10:31 AM
  5. Reusing Lead Closet Bend w/ Cast Iron Flange
    By Lakee911 in forum Toilet Forum discussions
    Last Post: 08-23-2005, 12:40 PM
