Results 1 to 9 of 9
Thread: What is this and what does it do for my NG furnace?
    DIY Junior Member greaper's Avatar
    Apr 2013
    Richmond, VA
    Default What is this and what does it do for my NG furnace?
    I have a rental house and the other day my tenant called to tell me that there was no heat or AC. After further investigation I found that I had a bad EZ-TRAP float switch. I also noticed that there was a pair of wires just hanging that I thought was connected to this device that is on the exhaust flue. Can someone tell me what these pictures are of and what is it used for? I am also not sure if there is supposed to be two wires going to the small device in front or just one?
Size:  39.0 KBName:  IMG_20130414_184502_222.jpg
    Feb 2011
    NW Ontario, Canada
    It is a barometric damper and a thermostatic switch that has been defeated.
    Apr 2013
    Richmond, VA
    Thank you for the quick answer. Two questions. What is a barometric damper? How is the thermostatic switch supposed to wired? I assume that if the temperate rises to high at the switch that it is supposed to cut off the unit?
    Feb 2011
    NW Ontario, Canada
    I'm not a HVAC tech so I cannot cite code, but that thermostatic switch does not look like a code compliant setup. I think it was probably something that a well meaning DIY'er jury rigged. My guess is it was meant to detect a flue reversal (downdraft). I would use a CO detector to monitor for flue reversal.
    The barometric damper regulates the amount of draft by mixing in cooler room air whenever the draft is too strong.
    Mar 2011
    Houston, TX
    Quote Originally Posted by greaper View Post
    It is a 180 degree Presidential solution. And it does not belong there.
    Apr 2013
    Richmond, VA
    Again, thank you for the replies. I guess based on that I will remove it and not worry about it.
    Mar 2011
    Houston, TX
    Did you find the original problem with it ? Why it was not working.
    Apr 2013
    Richmond, VA
    Yep, it was the EZ-TRAP float.
    DIY Junior Member Failure2Comply's Avatar
    Sep 2012
    Virginia, USA
    Someone installed an warp disc limit (180F "Flue Draft Spillage") switch on your barometric relief damper. They must have had a venting issue and band-aided the problem.
  1. 60,000 vs 80,000 BTU furnace
    By CurbYourEnthusiasm in forum HVAC Heating & Cooling
    Last Post: 02-18-2013, 05:11 AM
  2. Conversion from gas furnace to electric furnace
    By debka in forum HVAC Heating & Cooling
    Last Post: 01-19-2013, 06:39 AM
  3. Need Furnace recommendation
    By AJ1762 in forum HVAC Heating & Cooling
    Last Post: 06-06-2012, 02:56 PM
  4. please help furnace is junk!!!
    By dewaynegg in forum HVAC Heating & Cooling
    Last Post: 11-15-2007, 05:09 PM
  5. What furnace should we get?
    By Sincraft in forum HVAC Heating & Cooling
    Last Post: 09-02-2007, 01:13 PM
