Page 4 of 8 FirstFirst 12345678 LastLast
Results 46 to 60 of 114
Thread: Kerdi Board Shower Niches - Review of Schluter System's new shower ready made niches
  1. #46
    How many Schluter classes have you been to to see the techniques and learn from the people that make the Schluter shower system (I've been to two, one at CTEF and one in Plattsburg, NY, Schluter's US headquarters)? As tested, the US recommended system of installation works. I'm sure the methods used elsewhere that have different plumbing codes work for them as well. As an example of the fact that things change, in the US, you used to be able to build a shower with a 1.5" drain (still can in Canada), but there were certain situations where it was found that that didn't always work, so the US code changed to a 2" drain requirement. Will a 1.5" one work? Yes, most of the time. Doing more than code minimum is fine if it makes you feel better, and is prudent in some circumstances, but for the most people it's a waste of time, money, and effort. Declaring it as essential, is misrepresenting the product. Not using the product as intended and complaining about it is also misrepresenting the product.
    I don't have an issue with your technique, I'm sure that it is a solid build, but I do take exception to your rant that it is the 'only' way to do it right. 100,000s of successful shower builds over many years says something different...the system works as designed and presented.
    Having spent over 30-years dealing with ensuring things work reliably because people's lives were at stake taught me how to evaluate the risk-benefit of different methods...there rarely is a second chance to destroy that missile coming towards you that might blow up your world, or take down that airplane that threatens your way of life - you just have to ensure you do it right the first time, and the Schluter system that is used in the USA and is warranted by them works reliably. Should you decide to enhance it, is your choice, but it is not required when you follow the instructions and use good workmanship.
    And, by the way, I have a sister living in England, and yes, over the years have visited 5-6 times, so yes, I am quite familiar with not only England, but have lived in Germany for awhile...and Korea, Jordan, and Kuwait. So, I've seen how people do things - the mindsets are different. Keep your snide remarks out of the discussion. Recognizing your way is not the only successful way happens when you have an open mind and are willing to learn.
  2. #47
    Jul 2009
    North Vancouver, BC
    Default Kerdi Board Review: IT SUCKS BAD
    Posts removed by John Whipple
  3. #48
    Again with the rant and the snide characterizations...
    The reference to hundred's of thousands was for showers built, not the Kerdiboard. That's showers built in the USA with Kerdi and unmodified thinset. FWIW, others seem to like Kerdiboard, and they're in the process of building a second production line to supply demand. If it was such crap as you say, by now, people would have stopped buying it. I think it's been in the line for something like 5-years now, but would have to check to verify. Since others had a foam-core board and people were asking for it, they spent a few years trying different techniques on constructing it before they settled on the product you can see.
    If you take a Kerdiboard niche, lay it on a flat surface, and fill it with water (I don't care for how long, days, weeks), except for evaporation, it will not leak. So, set into a wall, why would you expect it to where, instead of standing water pressure, the tile got wet sometimes?
    Cadillac and Chevrolet build their cars on the same platform...that doesn't make Chevrolet a piece of crap, only less expensive. IOW, the frills you put on can easily add up, but if the guts are adequate, it can be construed as either a luxury product or a merely adequate one. Put together properly, as designed, warranted, the out-of-the-box Schluter Shower System works whether you believe it or not. Put whatever fancy design features or fixtures on top of it you wish, it's still basically a shower.
    As anyone who takes a class with Schluter, you get yourself there and home, and they pay for the training, room, and board. Nothing special, it's available to anyone who chooses to go that the regional sales manager/tech person approves. At least that's how they do it in the USA. The next time I see any cash or products for free other than what everyone gets at a class from John Bridge or Schluter will be the first time.
    As said previously, 30+ years of having to make cost/benefit decisions on things that people's lives depended on has given me a reasonable ability to look at the facts and make a viable decision on things.
    I've had enough of your comments, and unless I see something egregious, won't take the time to comment further. We all make mistakes, often because we don't understand or take the time to investigate the science behind it. You, obviously, don't understand how to use Kerdiboard, and have no faith in the NA instructions on how to build a shower with Kerdi.
  4. #49
    Jul 2009
    North Vancouver, BC
    Default Jim has left the Building !
  5. #50
    Jul 2009
    North Vancouver, BC
    Default Kerdi Flood Test Inspection Failed because of Liquid Membrane Over Lap
  6. #51
    What do you think makes stuff like Wedi and Kerdiboard waterproof...it's the foam. Each (and any other one out there) use a proprietary layer on it to provide thinset compatibility. As I said, you do not understand KerdiBoard.
    Schluter has (several, depending on the norms and preferences of the country/region) methods of building a shower...the use of unapproved thinsets or other topical waterproofing materials is not in the instructions. So, why bring up a shower built improperly that failed? Build it per their instructions, and it is waterproof and will be warranted by them if your workmanship is up to par. The TCNA guidelines do not show extra stuff, so technically, it is not an approved method.
    Who are you going to believe, a company that has hundreds of thousands of successful showers built according to their instructions and the certification from an internationally recognized testing agency http://www.icc-es.org/reports/pdf_files//ESR-2467.pdf that says it meets all requirements for a proper, waterproof shower; or, someone who doesn't believe them or understand their product? Here's the UPC approval for the USA and Canada http://pld.iapmo.org/file_info.asp?file_no=0004654 Both of these ONLY apply if installed per the manufacturer's instructions.
    Last edited by jadnashua; 10-05-2013 at 10:10 AM. Reason: added ICC report reference and UPC approvals
  7. #52
    Jul 2009
    North Vancouver, BC
    Default Kerdi Board Testing - A Review of Schluter's new backer board
  8. #53
    Jul 2009
    North Vancouver, BC
    Default Kerdi Board vs Drywall: Review of water wick test
  9. #54
    Used as directed, the certifying agencies and the factory that makes and warrantees the stuff all agree that it works. Guess it's your inappropriate use verses the masses. You do not understand the stuff, and apparently never will.
    When used in a shower, the edges are either sealed with KerdiFix or banded to Kerdi. When done as instructed and designed, it works. There will be no standing water to create your horror world of improper use of the stuff.
    You can take most any product, install it improperly, or use it in a manner not designed, and have it fail. What, if anything does that prove?
    You do not understand the stuff, and probably never will. When used as designed, and installed properly, it works.
  10. #55
    Jul 2009
    North Vancouver, BC
    Default Kerdi Board Testing. What have we proved? Answers revealed...
  11. #56
    As mentioned in another thread, if you read Schluter's Shower Manual (which the Kerdiboard data sheet references when using it for waterproofing, i.e., in a shower), and you look at the steam shower section, it only lists Kerdi and KerdiDS as suitable for steam showers...the fact it failed in a steam shower is not a fault of the product, it is a fault of the installer using the wrong materials and techniques.
    Earlier, John showed a picture of his installation of a Kerdiboard niche, he had a screw about every 4" or so around the periphery. Schluter's instructions call for screws no closer than 12" apart with one in each corner. If it was then covered up to the opening with Kerdi or Kerdiband, as designed, the whole thing would be waterproof. The instructions say, when using the optional shelf, to install the tile up to the bottom edges, then insert the shelf using thinset or KerdiFix, then finish the tiling. The tile provide additional support to ensure it stays, and they say to add some slope, if you wish, to prevent pooling, or to do it with the tile.
    A good example of not following the manufacturer's instructions.
  12. #57
    Jul 2009
    North Vancouver, BC
    Default Q: Can Kerdi Board Be Used in a Steam Shower - A: It depends on who you ask
  13. #58
    Jul 2009
    North Vancouver, BC
    Default Kerdi Board vs Wedi Board - Which is better for a steam shower?
  14. #59
    If, as I said, you read the Kerdiboard data sheet, it says for wet areas, like showers, use the Schluter Shower Systems Manual, and in the steam shower section, it only lists Kerdi and KerdiDS...Kerdiboard is mentioned in the normal shower section of that manual, but is NOT shown in the steam shower section.
    Calling Schluter Tech Support will give you permission to do some things not in the manual, like the use of a rapid set mortar if your glass tile manufacturer is adamant about it. But, the manual does not show KerdiBoard in the steam shower section at all.
    The shower you showed, was a commercial shower, so in that situation, should not have used the material. And, without careful attention to routing and placement and sealing of the steam lines and outlets, even a residential steam shower could be at risk. Cost/benefit/risk for most people, like the manual says, probably would not want to use it in a steam room. Both the steam supply line and the outlets could easily be hotter than the material's max spec, depending on how routed and installed. Cost/benefit/risk to me is too high for a steam shower.
    Just like you say you never use studs in a shower curb, but TCNA says it's fine, you have different cost/benefit/risk tolerances.
  15. #60
    Jul 2009
    North Vancouver, BC
    Default Q: How Much Does Kerdi-Board Cost - A: Lots
  1. Do Noble Niches Have The Bottom Shelf Slope Built Into Them?
    By DanMcD in forum Shower & bathtub Forum & Blog
    Last Post: 03-10-2013, 08:42 PM
  2. pre-formed shower niches
    By Richard S in forum Shower & bathtub Forum & Blog
    Last Post: 11-07-2011, 06:31 AM
  3. Orange Mold in a Schluter Systems Kerdi Shower - Linear Trench Drain
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 06-14-2011, 08:54 AM
  4. Bathroom accessories and ready to tile niches
    By Moses Cohen in forum Shower & bathtub Forum & Blog
    Last Post: 03-22-2011, 10:23 AM
  5. Schluter-Kerdi shower install needed
    By cclearly in forum Shower & bathtub Forum & Blog
    Last Post: 10-31-2008, 01:06 PM
