Results 1 to 2 of 2
Thread: Schedule 20 for Tub Drain?
    DIY Junior Member
    Apr 2013
    Pittsburgh
    Default "1-1/2 plastic Tube" for Tub waste and overflow?
    I am installing a new tub in my 2nd floor bathroom and trying to select the drain hardware. The local big box store sells tub drain kits using either "1-1/2 inch plastic tube" or Schedule 40 PVC.
    The advantage of the "1-1/2 inch plastic tube" system in my situation is the pipes and joints are smaller (the space is tight) and they screw together so I can adjust the fit if they don't go together exactly right the first time.
    The kit I'm referring to using "1-1/2 inch plastic tube"
    Name:  keeney plastic kit.jpg
    The manufacturer describes the tubing as "1-1/2 inch plastic tube" and it's the same system you might see used for an inexpensive sink trap: white plastic with compression fittings that you screw together. No glue like regular schedule 40 PVC.
    I understand why a leak under a tub is bad (won't be able to see, mold, etc.) and I definitely want to avoid a leak.
    The guy at the store argued strongly that I should NOT use "1-1/2 inch plastic tube" for a tub drain because it will leak. Makes me wonder why they sell them, but i guess that's what you get at big box stores...
    I see lavatory drains all the time that use the "1-1/2 inch plastic tube" system. Why can't I use that same system for a tub waste and overflow? Is this type of system inherently more likely to leak?
    Thanks for your advice!
    MrMax
    ps - I edited my original post because I was referring to the system as 'schedule 20' which is apparently not the right name. Also cleared up that I am referring to a tub waste and overflow kit.
    Consultant cwhyu2's Avatar
    Aug 2007
    Cincinnati OH
    What you are refering to is a waste and overflow,the parts that attach to the tub.Am I correct? This is what I have installed on all the a lot of tubs.
  1. Schedule 30 for toilet drain?
    By mar3232 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-20-2013, 06:32 PM
  2. Schedule 40 PVC vs. Schedule 40 Foam Core
    By ROSSBYINGTON in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 04-10-2008, 03:48 PM
  3. Installing new Schedule 40 Bath Drain
    By mi21stinf in forum Shower & bathtub Forum & Blog
    Last Post: 04-08-2008, 07:40 PM
  4. one more ??? schedule 40 pvc
    By coach606 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-07-2006, 06:04 AM
  5. Schedule 40 PVC vs. Schedule 40 Foam Core PVC
    By Fran in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-09-2005, 09:44 AM
