Thread: Pipe protrudes past studs entire length of wall
    DIY Junior Member jmwebguy's Avatar
    Apr 2013
    Minnesota
    Default Pipe protrudes past studs entire length of wall
    I was planning to hang some drywall in my unfinished basement in the house I just purchased. I have 2 questions and am hoping someone can help. There is a picture to explain.
    1) I have a pipe to extends the full length of one of my walls, about 20ft. It protrudes past the studs I would attach the drywall too, by about 1/2". In the picture you'll see the pipe and the main stud to the left (question 2 below pertains to the framed opening which you will also see).What are my options?
    2) As you'll see in the picture, where the pipe starts, to the left in a framed opening, but it's about 2" past the main part of the wall. Would you recommend I do something on the 20ft wall so that it aligns up with this opening, and then resolves the pipe issue in #1?
    If so, what would you recommend I do to align them up, given the 20ft wall?
    I hope this makes sense. Thanks for the help!
    Jan 2008
    Normally for something sticking out, I would either frame and drywall around the protrusion, or for a long section of wall with a shallow protrusion we would look at furring the entire wall out.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    I really need to see a bigger picture to tell you what I would do.
    Where the pipe is sticking out an inch, you could strip the wall. By striping I mean adding 2x2’s and or 2x4`s to the existing studs. You would need to strip the sole plate and the top plate so you will have something to attach base board and molding at the top etc. This would build the wall out 1 and a inch and the pipe would not show or be in the way.
    You could build a box around the elbow or build a box or enclosure that extends the full length of the wall so it is not so obvious. You might be able to change the pipe but I cannot tell in your picture.
  1. "Notching" studs vs. holes in studs for copper pipe?
    By ironspider in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-08-2013, 08:02 AM
  2. Plastic Pipe Insulators / Brackets thru Studs for Copper Pipe -- When Required?
    By speede541 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-11-2011, 10:44 PM
  3. fixing wall that bows out past door frame
    By cam100 in forum Remodel Forum & Blog
    Last Post: 02-08-2010, 04:12 PM
  4. Plumbing Wall with no studs??
    By medeamedea in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-31-2009, 10:04 AM
  5. Does entire shower stud wall need to be pressure treated?
    By Mike Fresh in forum Shower & bathtub Forum & Blog
    Last Post: 12-07-2008, 07:55 PM
