Page 4 of 4 FirstFirst 1234
Results 46 to 57 of 57
Thread: Softener settings
  1. #46
    Quote Originally Posted by mialynette2003 View Post
    You ever wonder why I have a problem with you? You ever wonder why a lot of others have a problem with you? The common factor is you. You bash people at the things they say like you are the GURU of water treatment. Just like your opinion of my instructions. I offered them, but the OP didn't take me up on the offer so now he has some questions. And this is why I say you have a bag full of cheap shots. You don't know the whole story but you will make a comment like that. When you talk about being negitive, look in the mirror.
    No I don't wonder why you have a problem with me. I used to be just like you. Nor do I wonder about those others either. Remember that I reply to what y'all say, not about you as to what kind of person you are or where you live or how you live.
    Your instructions were not included and my mistake was thinking you would have sent them to all your customers if they wanted them or not but... me, I wouldn't sell to anyone that refused my instructions or if I had the slightest idea that they wouldn't follow them.
    And as we see, the OP has had many questions. Many of which I would have answered before he bought from me because I know prospective customers usually don't know enough to ask questions about everything they will need to know. I even had them write down programing info and the data before they bought from me. And asked them if they had any questions about that. Some of those people I educated didn't buy from me, or then but came back in days to up to a few years later. I talked to every internet customer I sold to.
    I also I notice that your customer was interested in me answering at least some of his questions... That alone should have got your attention but it seems as if it hasn't. Or, you too were relying on me. I usually smile while typing replies but now I'm grinning pretty wide over that.
    Tntent, you're welcome.
  2. #47
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    Sounds to me you have a much different way of thinking than I do. IMO, you sound more like a dictator, (do it may way or I won't sell it to you). Thanks, but no thanks. I'll stick to my style.
  3. #48
    DIY Junior Member tntent805's Avatar
    Mar 2013
    calif
    Default reserve regeneration
    One more question, since this softener is a clack ws1 cs, 2 cf unit, I think u guys said it uses a variable reserve, at what point should I expect it to regenerate ? And how does
    the ws1 cs calculate the reserve.
    Tks
    Tntent
  4. #49
    Nov 2010
    Ocala, Florida
    It regens based on your daily usage. It collects data of your usage over time and calculates when it needs to regen.
  5. #50
    Mar 2013
    calif
    Default System regenerated
    Last night unit went to 0 gal. remaining.
    After it went to zero, I used my Hatch 5B and it was blue without using any drops of solution. At 2:00 a.m. unit regenerated and I tested the hardness again. Today, it took one drop of solution to turn water tested blue.
    Settings were at 45, 000k, hardness set to 23,
    13.5 lbs salt dose. Override set to 14 days.
    Clack ws1-cs set to P14
    ( post, downflow.
    1st. bw = 8,
    Brine Slow Rinse = 60,
    No 2nd. Bw.
    Fast rinse =6
    Thoughts, suggestions, etc.
  6. #51
    Nov 2010
    Ocala, Florida
    You stated you tested the hardness and it came up 26 grains. If that is the case, you will have hard water prior to a regen in the future. It may take some time because with a new unit you have full capacity (30K per CF). This capacity will slowly be used up because of the hardness being higher than programed.
  7. #52
    Mar 2013
    calif
    If I change the hardness setting to 26, should the
    k, capacity be left at 45k, or does it need to be changed to 40k ?
  8. #53
    Nov 2010
    Ocala, Florida
    Leave at 45k if you want and test just before a regen several times to insure no hard water prior to a regen.
  9. #54
    Mar 2013
    calif
    K, but should I change hardness to 26 ?
  10. #55
    Nov 2010
    Ocala, Florida
    The unit must be set on the incoming hardness. So if you measured 26 gpg, the unit must be set for 26 gpg.
  11. #56
    Mar 2013
    calif
    Am I correct, in changing the hardness setting from 23 to 26, that only changes / effects the water after the next regeneration ?
  12. #57
    Nov 2010
    Ocala, Florida
    No. It will not effect the water quality at all. Lets put it this way. If you need to travel 26 miles but only put enough gas in the travel 23 miles, what's going to happen? If your hardness is actually 26 and you have the unit set on 23, you are going to run out of soft water prior to a regen. It may not happen right away, but it will happen.
  1. Softener Settings Advice
    By djbarber2 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-02-2013, 11:46 AM
  2. Softener settings
    By bishoptf in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-06-2013, 08:23 AM
  3. Recommended best settings for 6700xtr 48,000 grain water softener
    By Lost Texan in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-05-2011, 08:30 PM
  4. Water Softener settings
    By OhioTurner in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-31-2011, 02:46 PM
  5. Settings for our new Fleck 2510sxt 48,000 gr. softener w/ 1.5 cu' SST 60 resin
    By k8ie in forum Water Softener Forum, problems, installation and reviews
    Last Post: 04-08-2011, 08:12 PM
