Results 1 to 9 of 9
Thread: water constantly draining need help not sure if its pressure tank or softener problem
    DIY Junior Member marisa rae's Avatar
    Apr 2013
    candor ny
    Exclamation water constantly draining need help not sure if its pressure tank or softener problem
    We have a aqua air v60 pressure tank and an rainsoft softner.... water is constantly draining from somewhere? but it looks like it's originating from the pressure tank... It's snaking through the basement to the drain for the washing machine.. where the softener system normally drains and normally the system only drains when it cycles which is once a day. The system is NOT cycling but the draining continues?? Help? What is causing this and should i call the softening system repair guy or a plumber? Thank so much ...Need help asap as the repair guy could be here this afternoon....
    Jan 2008
    The tank could be leaking or the softener could be malfunctioning. You should shut off the power to the well pump until you can get someone there to properly diagnose the problem.
    Apr 2013
    candor ny
    i figure out the water softener bypass.. and it's not the softener ..thanks so much,
    Marisa
    Apr 2013
    candor ny
    Exclamation Pressure tank or water softener? Water constantly draining-- Need input
    Update: So when I bypass the softener the drain is still continuing. The water softener repair person is insisting it's the water pressure tank and I called a plumber who is insisting it's the water softener... When I turn on all the faucets upstairs or the washing machine the water stops draining and seems to reverse initially. the pressure in the pressure tank now that I've removed a wall to get to it ( thank previous owners!) is 34...
    Help? Who to call?
    Jan 2008
    I don't think there is any need for a rocket scientist here. Use towels, fans, etc to dry the area between the fixtures so you can tell which side the water is coming from.
    Apr 2013
    candor ny
    it's draining through a clear hose...which I'm assuming is the water softener but the technician doesn't think so...no moist/damp fixtures..no pressure loss...no spillage.
    Jan 2008
    And where is the clear hose coming from? If I had to guess, I would think the control head on the water softener.
    Feb 2011
    NW Ontario, Canada
    Ja, just follow the clear hose.
    Nov 2005
    Central Florida
    Does the effluent taste salty?
  1. Draining a water softener into a septic system...bad idea?
    By Mikebarone in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 06-24-2013, 06:20 PM
  2. Water pressure tank pump recycling constantly on cut in
    By Craig95005 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 02-11-2013, 06:29 AM
  3. Draining Water Softener - Seasonal Cottage
    By chuck b in forum Water Softener Forum, problems, installation and reviews
    Last Post: 07-19-2011, 04:11 PM
  4. Water softener draining
    By Pedelty in forum Pumps and Tanks Well Forum & Blog
    Last Post: 12-26-2008, 10:30 AM
  5. Well pressure problem and pump runs constantly
    By jmustang9150 in forum Pumps and Tanks Well Forum & Blog
    Last Post: 01-15-2008, 08:46 AM
