Results 1 to 6 of 6
Thread: Vertical Wet Venting Question
    DIY Junior Member sethamin's Avatar
    Feb 2013
    Brooklyn, NY, United States
    Default Vertical Wet Venting Question
    Is the following wet venting permissible under UPC?
    I'm pretty sure the answer is no, but thought I'd check with the experts just in case, since it would make my life easier.
    Feb 2013
    I think this is the relevant section of 2009 UPC:
    908.1 Vertical Wet Venting.
    908.1.1 Where Permitted. Wet venting is limited to vertical drainage piping receiving the discharge from the trap arm of one (1) and two (2) fixture unit fixtures that also serves as a vent not exceeding four (4) fixtures. Wet-vented fixtures shall be within the same story; provided, further, that fixtures with a continuous vent discharging into a wet vent shall be within the same as the wet-vented fixtures. No wet vent shall exceed six (6) feet (1,829 mm) in developed length.
    This doesn't seem to disallow it, but I still seem to recall reading somewhere the UPC disallows wet venting into vertical drainage. Maybe 2012 UPC has some changes on this?
    Anyone?
    quote; recall reading somewhere the UPC disallows wet venting into vertical drainage.
    That is the way the majority of wet venting is, and always has been, done. But, unless that is a side inlet sanitary tee for the tub connection it is wrong,. It cannot go into a double "Y or double combo. The lavs cannot use a double combo OR a sanitary cross, it must be a "back to back fixture fitting".
    Feb 2013
    What about a double fixture fitting for both of them?
    Do you realize what a 3" B2B fixture fitting costs?
    Feb 2013
    Well, I do now. They're pricey. I just have to figure out if it's cheaper to do that rather than running an individual vent for the toilet and tub and tying them back in above.
  1. Question: Geothermal Vertical Closed Loop
    By steve2278 in forum Solar and Geothermal Water Heating Forum
    Last Post: 01-21-2013, 08:54 PM
  2. Utilitech Vertical pressure tank question
    By pjw302 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2012, 11:08 AM
  3. Vertical Drop before venting
    By suntex01 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-17-2010, 07:32 PM
  4. Question about venting
    By lindyq in forum Water Heater Forum, Tanks
    Last Post: 02-16-2010, 10:21 AM
  5. Venting question in Ma.
    By canton in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 02-19-2008, 07:28 AM
