Results 1 to 5 of 5
Thread: Should I use sodium or potassium salt?
    DIY Senior Member amateurplumber1's Avatar
    Mar 2013
    Here
    Default Should I use sodium or potassium salt?
    Any differences, besides cost? I wonder if it will increase my sodium intake a lot. Thanks!
    Quote Originally Posted by amateurplumber1 View Post
    Heart Doctors recommend potassium because sodium will sometimes leave some sodium behind and personally its less slippery feeling.
    Feb 2011
    NW Ontario, Canada
    LOL Cost is a huge difference in and of itself. Efficiency is another... salt being more efficient. The amount of sodium added to the water depends on how much hardness it had to remove. Unless you are on sodium restricted diet, I would not worry about it. If you are worried, use an RO filter to remove the sodium.
    Jan 2012
    California
    Sodium. Potassium not only cost a lot more, it also should be set up differently than sodium. It is too technical to go through right now (I have to get to my daughters Hockey game), but... potassium is not a good idea in general.
    DIY Senior Member lifespeed's Avatar
    Apr 2007
    California
    RO water is really nice to drink. Once you try it it is hard to settle for less. I have taste tested my carbon-filtered, softened water against the RO water and it is night and day. RO systems are not that expensive.
    It does kind of spoil you. Every once in a while I'll have a fountain soda and taste the chlorine.
    Lifespeed
  1. an electronic way to test my water hardness using sodium instead of salt
    By jasper7821 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 10-08-2012, 11:23 AM
  2. Test for salt/sodium levels in water
    By mrmichaeljmoore in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-18-2009, 08:15 AM
  3. Converting from Potassium to Sodium
    By marks2 in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-02-2009, 05:59 AM
  4. Water Softeners-Potassium or Sodium Exchange Resin?
    By markmc00 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-02-2005, 11:35 AM
