Results 1 to 5 of 5
Thread: How to stop bathroom sink leak
Hybrid View
    DIY Junior Member Scottc123's Avatar
    Dec 2012
    Long Beach
    Default How to stop bathroom sink leak
    Hello,
    I just installed a new sink and vanity, I'm having one annoying issue: the long (approx 8") portion at the end of the P-trap which goes into the wall is leaking where it meets the metal drain pipe coming from the wall (small drip from bottom where they meet). There are no fittings at this part just a straight 6" of PVC which fits snugly into the metal pipe coming from the wall, so I'm confused on how to stop this leak. Is there something that I can wrap around the PVC? It is super tight as is now so I am not sure what would work....
    Anyway any help would be appreciated, thanks
    DIY Junior Member 6t7gto's Avatar
    Jan 2010
    Bedford, Ohio
    Post a pic of what you have done.
    I'm guessing you need a trap adapter.
    Them come in plastic and metal.
    http://www.homedepot.com/p/NIBCO-1-1...-2-7/100347086
    Aug 2009
    South*East
    If the pipe is 1-1/2 galvanized you need a slip joint washer and lock nut.
    quote; If the pipe is 1-1/2 galvanized you need a slip joint washer and lock nut.
    That is about the best way to guarantee that the end of the galvanized pipe will "rust away". Use a brass female trap adapter and prevent it from happening.
    Aug 2009
    South*East
    How would a brass female adapter be any better than a brass brass or plastic slip nut?
    John
  1. re: bathroom sink leak on new installation -picture included-
    By gramps416 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-24-2011, 07:52 AM
  2. dry ice to stop a leak
    By tregg in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-03-2010, 06:25 AM
  3. Leak under bathroom sink
    By dzy5kl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-12-2010, 05:37 AM
  4. Angle stop valves for bathroom sink
    By bjferri in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-21-2008, 09:07 AM
  5. Leak under bathroom sink
    By snood in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-07-2005, 07:40 PM
