Results 1 to 6 of 6
Thread: Kinetico water softener
    DIY Junior Member snifferpro's Avatar
    May 2011
    Phoenix, AZ
    Default Kinetico water softener
    I have a model 50 Kinetico system.
    Just yesterday I noticed i'm no longer gettting soft water.
    I used a test strip to check and it's definitely hard.
    I then ran the water long enough for the system to switch
    tanks and checked with a strip again. No soft water.
    I had a similar issue 2 years ago. In that case, I would get
    soft water only from one tank. When it switched to the other
    I would get hard water. Switch again and I would get soft
    water. Turned out that the tube that goes down the center of the
    tank had snapped a couple of the tines in the tank that would give
    hard water. Had both tanks replaced and all was fine.
    Now, I get hard water from both tanks.
    Is there something easy I can check to see why i'm not getting
    soft water?
    Is there salt in the tank?
    Has it been suing salt?
    Does it suck brine when in regeneration?
    May 2011
    Phoenix, AZ
    There is definitely salt in the tank.
    I just noticed this problem yesterday so I don't know if it sucks brine. It has been using salt as I added some just over a week
    ago. As for sucking brine, I'll have to force a tank switch to check.
    I will keep track of the salt usage.
    DIY Senior Member mialynette2003's Avatar
    Nov 2010
    Ocala, Florida
    If you put the unit into a brine/rinse cycle, you can disconnect the brine line from the valve and feel if it is drawing. If it is, switch to the other tank to see if it is drawing on that tank. There will be water coming out of the brine connection when you change tanks. If you have a draw on both tanks, check to see if it is metering by opening up a faucet inside the house and watch the no back pawl. You should see it ride up one tooth of the meter disc and drop into the slot of the next one. i have exploded views of the internal parts. If you need one, drop me an email ans I'll send it to you.
    May 2011
    Phoenix, AZ
    I'm about to check it out now
    May 2011
    Phoenix, AZ
    OK, I just regenerated twice. water is being sucked out of the tank and being replenished
    Couldn't tell if the pawl moved at all (these old eyes don't work as good as they used to.
  1. Plumbing reversed on Kinetico water softener
    By rmb in forum Water Softener Forum, problems, installation and reviews
    Last Post: 09-07-2011, 06:59 PM
  2. kinetico water softener
    By edward.arnold in forum Water Softener Forum, problems, installation and reviews
    Last Post: 11-25-2009, 06:28 PM
  3. kinetico water softener problem
    By firedudedon in forum Pumps and Tanks Well Forum & Blog
    Last Post: 03-31-2009, 05:53 PM
  4. kinetico water softener problem
    By firedudedon in forum Water Softener Forum, problems, installation and reviews
    Last Post: 03-31-2009, 01:10 PM
  5. Remove Kinetico Water Softener System
    By AjayK in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-18-2009, 05:47 PM
