Thread: Trouble flushing a water heater
    DIY Junior Member David212's Avatar
    Mar 2013
    Illinois
    Default Trouble flushing a water heater
    I had my hot water re-plumbed due to the copper lines corroding. After everything was done the hot water was discolored. At this point I thought it would be a good idea to flush the tank. I have a traditional 40 gallon tank running on natural gas. I hooked up the garden hose to the plastic drain and opened the valve. All I got was a little trickle of water. I opened the faucet closest to the tank with no change. Normal flow of water out of the faucet. I tried various combinations of having the faucet on/off, cold supply on/off and hot valve on/off. The drain valve is all the way open but the best I could get was 2-3 cups of hot water. What am I doing wrong? Am I missing some step? I get normal water flow from all faucets in the house. After a week of normal use the color has gone away but I would still like to know what I am doing wrong.
    DIY Senior Member Smooky's Avatar
    Apr 2011
    NC
    Sediment may be blocking the drain.
    Check out this link:
    http://www.democraticunderground.com...dress=287x9045
    Many of us replace the original drain valve with a 3/4" ball valve when we first install the heater. Think might help, but even then you may need to ream the crud with a piece of coat hanger wire. I've seen sediment so deep even that wouldn't clear the tank.
    Jan 2008
    I've had to remove the valve so I could use a piece of rod to break free sediment blocking the opening in the bottom of the tank.
  1. Trouble Emptying Water Heater
    By foxhome01 in forum Water Heater Forum, Tanks
    Last Post: 02-22-2009, 10:06 PM
  2. Water Heater Trouble Shooting
    By IaHawk in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 03-28-2008, 06:55 AM
  3. Hot water heater trouble
    By needsomefun283 in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 07-01-2007, 03:32 PM
  4. water heater trouble
    By kbailey45us in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 12-19-2006, 05:20 AM
  5. Hot Water Heater trouble
    By soccergirl in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-11-2004, 09:04 AM
