Results 1 to 11 of 11
Thread: P-Trap Drain Not Draining Issue
    DIY Junior Member jms87's Avatar
    Apr 2013
    Cambridge, Ontario
    Exclamation P-Trap Drain Not Draining Issue
    I have a p-trap drain in my restaurant that isn't draining, when we disconnected the dishwasher drain hose water sprayed out of the drain end like it was under pressure. The dishwasher had not been run for over a week. I have taken the trap apart, snaked it out. I have also snaked all the other lines of this system yet the drain just fills with water. I don't believe any water is leaving through this p-trap, the water will over flow over the top of the drain line if I continued pouring water. I will attach a picture I think the issue is someone has tied this "drain" into a vent line. I have a two vent pipes in the sink area (very close together), one on the other side of the wall before the grease trap and one after the grease trap before the exit to the sewer. ant suggestions? Thanks!
    Nov 2010
    Maine
    The drain is plugged and you will need to call someone with the right equipment
    Have you checked to see if the grease trap is allowing water in?
    It may be time to clean it.
    "Connecting to a vent" if it is installed properly, does NOT cause drainage problems. you have a drain line stoppage. I hope the dishwasher drain line is not "connected" to the system without an |"air gap", so that any "backflow water" could contaminate the dishes.
    Apr 2013
    Cambridge, Ontario
    Yes the grease trap is open, I have 2 dishwashing sinks and one hand washing sink that goes to the trap with no issues. So only place a blockage could be is at the bottom of the pipe shown on the left, yet all the other sinks drain through the main also...
    TROJAN WORLDWIDE SALES RP MACPLUMB 777's Avatar
    Aug 2007
    Houston, Texas, United States
    The drain pipe is much more then just at the bottom it will run out 5,10, or more feet and any or all of it could be clogged with grease and that is why you need a professional drain person to clear the drain !
    MACPLUMB 777
    E-MAIL
    JERRYMAC@TROJANWORLDWIDE.COM
    35 YEAR MASTER PLUMBER, HEATING, ELECTRIC, DRAINS, FIRE SPRINKLERS, WATER HEATER
    AND BOILERS SINCE JAN, 1989
    281-706-1631 7 DYS A WEEK SALES AND TECH. SUPPORT
    Trojan Worldwide Web Site
    Apr 2013
    Cambridge, Ontario
    Quote Originally Posted by MACPLUMB 777 View Post
    This p-trap drain line is after my sinks, before my grease trap yet all the sinks drain with NO issue. So if a clog is present it has to be at the bottom of the line shown on the left, which is about 12-18" long?
    Jan 2008
    The clog is likely right there in one of the bends in the line .
    I would cut out a section of the vertical vent line and rod the drain, and then install a cleanout where I cut the line for the next time it needs to be done.
    Apr 2013
    Cambridge, Ontario
    I'm in the process of doing this, having a hard time finding 1 1/2 PVC Fittings here, can I use ABS if its only for the vent line? No water flow. I have cleaned my grease trap and it was quite bad so I bet there is a clog at the bottom of the line.
    Jan 2008
    There is a special transitional cement for bonding PVC to ABS. I would look harder for the PVC fittings first.
    If you want to do some trading, I could use a couple of ABS continuous waste with end outlet kits. ABS is quite uncommon here.
    Apr 2013
    Cambridge, Ontario
    I found the PVC fittings, had to call the local pluming store (One Stop Plumbing).
    I found there was a clog in the bottom of the line, and this is why the p-trap wasn't draining. I was able to free it up using my snake, and I also got good drain cleaner and put it down all my drains.
    Thanks for all the suggestions everyone, much appreciated. I will now keep an eye on the grease trap and maintain it.
  1. Slow draining tub a vent issue?
    By diyright in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 01-02-2013, 03:12 PM
  2. shower to tub drain issue ( 1 1/2 to 2 p-trap)
    By clapfc in forum Shower & bathtub Forum & Blog
    Last Post: 11-27-2012, 12:10 PM
  3. Toto toilet tanks not draining when flushed - flapper issue?
    By Melissa2007B in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-12-2011, 10:59 AM
  4. 3 compartment sink draining problem with grease trap
    By pizzaworker in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-13-2010, 07:23 PM
  5. Tub draining issue
    By lissiealkie in forum Shower & bathtub Forum & Blog
    Last Post: 09-18-2005, 02:10 PM
