Page 2 of 4 FirstFirst 1234 LastLast
Results 16 to 30 of 57
Thread: SpiderWeb II - Review of Custom Building Products new Uncoupling Mat
  1. #16
    DIY Senior Member suceress's Avatar
    Mar 2008
    LA
    I'd love to see how things turn out.
    Not to sound like a sycophant, but I really do think its awesome that you go to such lengths to test the products. I think it really is cool and it helps to have a better understanding of how the products work, their limitations, etc. Too bad there is no "like" button on this forum.
  2. #17
    The strength test is after full cure...shortchange that, and you risk failure. The industry standard is 50#/sqin for this type of material. Independent tests have shown the Schluter products to achieve at least 75#. Do it before full cure, I do not know the results.
  3. #18
    Jul 2009
    North Vancouver, BC
    Post(s) removed by John Whipple
  4. #19
    It's rated at the nominal 28-days. It's a shear measurement (parallel to the face), not a hanging measurement (perpendicular to the face), and this assumes a monolithic surface (i.e., grouted). You'd have to look up the specifics of the test. Schluter discusses it in their installation manual, and that may also list the test procedure. Need apples-apples if you want to run the test. Anything over 50#psi meets the industry code for this type of material. When Schluter had the test run, the testing agency came up with 75#psi as the fail point - 50% above the minimum.
  5. #20
    Jul 2009
    North Vancouver, BC
  6. #21
    No idea what kind of strength you'd have with a pull test. The vast majority of stress on tile is in shear, either from bending or if on a vertical surface, just from the weight. As noted, at least as I remember it, the 50psi industry rating is for shear, not pull. I'm not sure I've seen a pull test requirement.
  7. #22
    Jul 2009
    North Vancouver, BC
  8. #23
    On a wall would be more in line with my understanding of the test procedure.
  9. #24
    Jul 2009
    North Vancouver, BC
  10. #25
    I think the grout simulates a full wall install better, since it ties the stuff together. Makes it harder for the membrane to shear off, since it's sharing the load across a larger area. But, I have not read the details of the actual test procedure, so may be misinterpreting it.
  11. #26
    Jul 2009
    North Vancouver, BC
    Default SpiderWeb 2 vs Ditra & Noble Seal TS (Head to Head Challenge)
  12. #27
    Jul 2009
    North Vancouver, BC
    Default Installing Ditra with Ardex AF207
  13. #28
    Jul 2009
    North Vancouver, BC
    Default Thin-set used in testing
  14. #29
    Jul 2009
    North Vancouver, BC
  15. #30
    Jul 2009
    North Vancouver, BC
    Default Spider Web 2 Testing
  1. Building a Custom Electric Mirror - Sometimes simple is best!
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 12-05-2013, 10:10 PM
  2. Clarion products?
    By frmrnyker in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2011, 01:23 AM
  3. Information on Running a Frost Free Water Line from building to building
    By staysteady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2008, 10:07 AM
  4. Building our FIRST custom showerpan...need ADVICE!!!
    By Daniko in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2006, 08:10 AM
  5. Plumbing Products
    By RJ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2005, 04:58 PM
