Page 1 of 4 1234 LastLast
Results 1 to 15 of 57
Thread: SpiderWeb II - Review of Custom Building Products new Uncoupling Mat
    Jul 2009
    North Vancouver, BC
    Default SpiderWeb II - Review of Custom Building Products new Uncoupling Mat
    Post(s) removed by John Whipple
    Jul 2009
    North Vancouver, BC
    Default SpiderWeb II - Custom Building Products Data Sheet
    Jul 2009
    North Vancouver, BC
    Default A closer look at SpiderWeb II - Custom Building Products new "Ditra Like" Uncoupling
    Jul 2009
    North Vancouver, BC
    Jul 2009
    North Vancouver, BC
    Default Back to Back: Ditra vs Spider Web II
    Jul 2009
    North Vancouver, BC
    With Ditra, the anchor to the membrane is more the dovetail, and at least on that top surface, there is no fleece. The dovetails lock the tile in. The reason you can't use tile smaller than 2x2" on Ditra is those plastic dividers which are only there to create the dovetail pillars. The industry standard for bond strength of the fleece is a MINIMUM of 50#/sqin. Both Ditra and Kerdi typically test out at 150% of the minimum standard. It doesn't sound like this new product will meet that standard, and you are relying entirely on the mesh, both top and bottom to hold things in place...doesn't sound very reliable.
    Jul 2009
    North Vancouver, BC
    WIth that thick of a mesh, it may be enough to allow moisture to wick along the surface. ANd, as you mentioned, it would be very difficult to embed it entirely in the thinset, leading to potential soft surface, susceptible to deflection of the fleece. I'd have to see and try it, but from the pictures, it doesn't impress me.
    Jul 2009
    North Vancouver, BC
    DIY Senior Member suceress's Avatar
    Mar 2008
    LA
    I really love that you are into testing out new products. I wonder if the sample you were given was some sort of dud. But I imagine you thought of that already.
    What exactly is the purpose of these mats? I get that you put tile over them, but I don't know anything more about them than that. I know you mentioned Holmes on Homes as advertising products, but one thing I did note on that program was that they would put down some sort of mat underneath the tiles to sort of buffer it so it would be more forgiving if the subfloor wasn't perfect. At least that was my understanding.
    I wonder how these would work with in-floor heating... Would the heating things go on top of it? Or would something like this just not be used.
    I'm interested in seeing what you find with your Mad Lab testing.
    http://www.schluter.com/7214.htm pretty much tells and shows the intent of a good underlayment. The membranes are typically thin enough that they do not affect heat transfer when using in-floor heating systems.
    Mar 2008
    LA
    Thanks, jadnashua! I'm loading the video now.
    I'm no expert, but I would think that the thick fleece on the spiderweb II would not conduct the heat very well. Am I wrong on this? It looks like there is enough air in the fleece that it might work as sort of insulation-- unless it just gets very saturated with thinset/adhesive to the point that it wouldn't interfere.
    Its something to consider in testing perhaps?
    Edit: Finished watching the video. I had an "ohhhh! That's how it's done!" moment when I saw how they did the tiles that went a few inches up the wall. I also found myself picturing just how I would end up getting stuff messed up and askew if I were to try it myself. Anything with adhesive and I always end up getting it crooked. LOL.
    That was very informative.
    If the mesh gets embedded well into the thinset, it becomes a non-issue. I'm not sure you'd be able to do that with the new SpiderwebII.
    Jul 2009
    North Vancouver, BC
  1. Building a Custom Electric Mirror - Sometimes simple is best!
    By johnfrwhipple in forum Shower & bathtub Forum & Blog
    Last Post: 12-05-2013, 10:10 PM
  2. Clarion products?
    By frmrnyker in forum Shower & bathtub Forum & Blog
    Last Post: 07-04-2011, 01:23 AM
  3. Information on Running a Frost Free Water Line from building to building
    By staysteady in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-14-2008, 10:07 AM
  4. Building our FIRST custom showerpan...need ADVICE!!!
    By Daniko in forum Shower & bathtub Forum & Blog
    Last Post: 05-31-2006, 08:10 AM
  5. Plumbing Products
    By RJ in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-10-2005, 04:58 PM
