Results 1 to 7 of 7
Thread: Flowguard Gold CPVC vs PEX
    DIY Junior Member MountainMike's Avatar
    Apr 2013
    Floyd, Va
    Default Flowguard Gold CPVC vs PEX
    Does anyone have any experience with Flowguard Gold CPVC and it's performance/ease of installation vs PEX?
    Nov 2010
    Maine
    I score the match a tie at zero, zero
    As you can tell, Tom doesn't like plastic supply pipes! If I were going to chose between them, I'd go with pex. Copper is still the gold standard. To do it in pex, you'd want to 'upsize' the supply lines or at least carefully match the load with the supply since the ID is thinner than copper. A repipe is a lot easier with pex. On new, I'd have to think about it...lots of things to consider.
    I like PEX better then CPVC
    You would also have to up size CPVC. Just like PEX, the inside diameter is about a size smaller than copper.
    In this area, FloGard has been used for residential fire sprinkler systems for decades, but I have not seen any installed with PEX, but that does not mean it is not used for that purpose. CPVC has the disadvantage on needing many more fittings to install it, but it is also more rigid giving a better appearance.
    Nov 2010
    Maine
    Uponor/Wirsbo makes several "systems" for sprinklers and PEX
  1. Replace Flowguard Gold on a remodel?
    By Marc remodel in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 11-11-2011, 06:17 AM
  2. The Value of Gold
    By Cookie in forum Electrical Forum discussion & Blog
    Last Post: 02-01-2011, 05:21 AM
  3. flowguard gold
    By lameduck in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 09-20-2010, 05:25 PM
  4. Pex vs FlowGuard Gold
    By Earnie in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 10-08-2009, 11:19 AM
  5. Flowguard gold vs regular CPVC
    By bubbameetze in forum Plumbing Forum, Professional & DIY Advice, Tips & Tricks
    Last Post: 05-15-2008, 04:53 AM
